2015 Ford F-150 Fuse Box Location
MrJobun
  • MrJobun
Post #1 post 31st January 2021 - 03:15 PM
The Ford F-150 is America’s best-selling vehicle, period. As such, there is a high probability that if you are reading this, you own one, and you are searching for the fuse box location. The Ford F-150 has two fuse boxes.
The primary fuse box is under the hood, and it contains high output fuses, so be very careful when dealing with them. This fuse box is pretty big and one of the few things covered by a lid under the hood, so it will be easy to find.
The secondary fuse box is inside the cabin and beneath the dashboard on the passenger's side. To open it, simply pull and swing it to the side until you have the cover in your hand. Once you are done, you can place the cover back in the groove and press it back into place.
If you are looking for more information about fuses, you should consult the Ford F-150 Owner’s manual to get the answers.
