2008 Dodge Caliber Fuse Box Location - including the purpose of each fuse.
Mcleod
  • Mcleod
  • Senior User
Post #1 post 28th January 2021 - 10:41 AM
Has something in your Dodge Caliber stopped working and you think it's one of the fuses?
Dodge calls the fuse box the "Integrated Power Module" or IPM, which is located next to the air cleaner/intake under the hood.
There is a label that shows what each component is and the identification of each is typically printed on the inside of the cover, so you need to pull that cover off to take a look at what everything is.
If you can't read the printing inside or it has faded, here's a list of the fuses from the 2008 model you:
  1. Empty Fuse Cavity - Empty
  2. 15 Amp Light Blue - AWD/4WD ECU Feed
  3. 10 Amp Red - CHMSL Brake Switch Feed
  4. 10 Amp Red - Ignition Switch Feed
  5. 20 Amp Yellow - Trailer Tow
  6. 10 Amp
    Red - IOD Sw/Pwr Mir/Ocm Steering Control / Sdar / Hands-Free Phone
  7. 30 Amp Green - IOD Sense #1
  8. 30 Amp Green - IOD Sense #2
  9. 40 Amp Green - Power Seats
  10. 20 Amp Yellow - CCN Power Locks
  11. 15 Amp Light Blue - Power Outlet
  12. 20 AMP Yellow - Ignition Run/Accessory Inverter
  13. 20 AMP Yellow - Power Run/Accessories Outlet RR
  14. 10 AMP Red - IOD CCN/Interior Lighting
  15. 40 AMP Green - RAD Fan Relay Battery Feed
  16. 15 Amp Light Blue - Ignition Run / Accessory Cigar Lighter / Sunroof
  17. 10 Amp Red - IOD Feed / Mod-Wcm
  18. 40 Amp Green - ASD Relay Contact PWR Feed
  19. 20 Amp Yellow - PWR Amp #1 & Amp #2 Feed
  20. 15 Amp Light Blue - IOD Feed Radio
  21. 10 Amp Red - IOD Feed Intrus Mod/Siren
  22. 10 Amp Red - Ignition running Heat/AC/Compass Sensor
  23. 15 Amp Light Blue - Engine ASD Relay Feed #3
  24. 15 Amp Light Blue - Power Sunroof Feed
  25. 10 Amp Red - Heated Mirrors
  26. 15 Amp Light Blue - Engine ASD Relay Feed #2
  27. 10 Amp Red - Ignition Run Only ORC Feed
  28. 10 Amp Red - Ingition Run ORC/OCM Feed
  29. Empty Fuse Cavity -Hot Car (No Fuse Required)
  30. 20 Amp Yellow - Heated Seats
  31. 10 Amp Red - Headlamp Washer & Relay Control
  32. 30 Amp Pink - Engine ASD Control Feed #1
  33. 10 Amp Red - ABS MOD/J1962 Conn/PCM
  34. 30 Amp Pink - ABS Valve Feed
  35. 40 Amp Green - ABS Pump Feed
  36. 30 Amp Pink - Headlamp/Washer Control/Smart Glass
  37. 25 Amp Natural - 110 Inverter
If you're not sure exactly where to look under the hood, please take a look at the diagram below which will help you out.
Need to see the full dodge caliber owners manual or a different year model? Check it out over here: https://www.boostcruising.com/owners-manuals/dodge/caliber/
Hope this helps!
:: BoostCruising :: The Automotive enthusiasts site with extensive Car Sales, loads of Car Parts, mags, wheels and Tyre Sales, along with subs, tweeters, head units, speakers, heaps of Car Audio. Over a million Aussie's can't be wrong!
