Best Engine For R31.... - what should i go for?
Brendan_r
  • Brendan_r
  • Sympathy. In the dictionary between shit and syphilis.
  • Contributing Member!
Post #1 post 6th August 2007 - 09:45 PM
hey i was wondering i got a R31 and i wouldnt mind doing an engine swap....im more of a V8 person but yeah thought i might give this a shot. must be a turbo ofcorse any help would be greatly appreciated.
QUOTE (chaos @ Jul 1 2008, 08:38 PM) *
Keep Breno away from rums? Christ, why don't I find out the meaning of life while im at it :lol:
QUOTE (the red krawler @ Jul 4 2008, 05:42 PM) *
If you dont keep making stupid topics youre going to be kicked out of boostcruising.
If you are looking for sympathy it is in the dictionary between shit and syphilis.
vh-holden
twin turbo ls1 biggrin.gif best of both worlds
neil_se
The obvious and most cost effective route would be RB30ET/RB30DET
metalhead
QUOTE(neil_se @ Aug 7 2007, 10:47 AM) [snapback]1281311003[/snapback]
Yes, but if you say you like V8s, I believe the swap to a Holden V8 is a relatively simple one, there are a few R31s around with this conversion.
On the other hand, any RB motor will bolt straight in. Rb20, Rb25, Rb26, Rb30, assuming of course it is a Skyline (rb30 powered) rather than a Pintara (I think CA20 powered??). I'm not sure how different the engine mounts, gearboxes and everything else are between the Skyline and Pintara. I do know the Pintara only has a 25 spline Borg Warner, and the Skyline has a 28 spline, so they have a stronger diff. I believe the brakes are the same between the 2.
Anyway, if it has an Rb30, the simplest, most cost effective and most powerful for fewest $'s option is to turbocharge the existing motor. On the cheap, if it's a strong motor, whack in a decompression plate, buy some turbo gear (available very cheap for rb30's) and retard the timing, fit larger injectors and push 10psi through it and it'll be great fun and should last a fair while. Otherwise, for a few more dollars, pull it out, rebuild it with turbo pistons, and you can go as far as you want with the rebuild (forgies, RB25/26 head), or just do it fairly cheaply (cast turbo compression pistons and then just a basic rebuild), bolt a big turbo on the side and buy an aftermarket computer, microtech or similar. You can make as much power as you want, it's all a matter of what you can afford.
Realise that with much power you will probably smash the standard gearbox (if they're anything like vl's), it would be worthwhile upgrading to Vl turbo (MX7) or similar gearbox at some point.
SMiTHBRo
go a second hand RB25DET. the extra cash ontop of an RB20DET is definately worth it. heaps more torque!
Tom Tucker
VH45de mate. Nissan 4.5ltr V8 ftw. Very strong motor, easily handle a turbo if you're that way inclined. Vh45 + twin r33 t3s= 600hp on 10psi. Something to think about...
Brendan_r
QUOTE(metalhead @ Aug 7 2007, 11:01 AM) [snapback]1281311065[/snapback]
hey thanks for the reply. it is the skyline it has the rb30.....its a bit tired though its got over 300000ks on the clock. its got a turbo 5 speed though. what ya rekon a turbo rb is worth?
QUOTE(Tom Tucker @ Aug 8 2007, 12:54 PM) [snapback]1281314702[/snapback]
very tempting......
QUOTE(vh-holden @ Aug 7 2007, 09:21 AM) [snapback]1281310810[/snapback]
even more tempting biggrin.gif ...........
ryanscurry
I have an 1989 skyline r31 with no motor in it. i am trying to spend the least money i can. what motor can i put in it please
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
