1st September 2013 - 09:59 PM
Post |
Hi Guys Can you recommend a reputable shop that will be able to adjust the camber of my front wheels and take a quick look over to make sure all is okay? Preferably a "skyline specialist" although as you know, these cars as similar to other RWD jap cars I am located in Menai, Sydney 2234 This post has been edited by tripsteady: Sep 1 2013, 10:02 PM -------------------- 1997 NISSAN SKYLINE R33 S2
3inch Turbo back (Gtr cat + gtr front pipe) | Blitz turn flow intercooler | HDI dual stage boost controller + guage | Pedders Coilovers | 18x235 F 18x 255 rear | Uprated toyota manifold studs | Pod | Slotted rotors + QFM HPX pads Soon : Walboro fuel pump | High flow turbo | 550cc injectors | Stage 2 mv automatics shift kit | Tranny cooler |
matty the tv man
if its a skyline (which i assume it is) any suspension shop i.e pedders, fulcrum will be able to do it providing you have adjustable upper control arms. otherwise there is no factory camber adjustment for skylines |
matty the tv man
Skylines don't have Upper Control Arm on the front. You will need adjustable camber tops or the offset pin kit for the strut (which is not a great thing, go the camber tops) Don't listen to this guy, he has no idea. Adjustable camber top would do nothing and it is not possible to fit a camber pin as the strut mounts on a single pin |
EUniqe
R33 has a double-link setup up front, according to nolathane. no stock camber adjustment. |
