2003 Hilux Cd Wiring - Need info
thepurplepulsar
  • thepurplepulsar
  • New User
Post #1 post 24th December 2006 - 07:17 PM
Hey people,
For someone that has installed a CD player in their Hilux can you identify the wire colours on the standard radio loom:
Light Green -
Blue -
Purple -
Pink -
Dark Green -
Brown -
Blue/ Yellow - Constant Power
Silver - Accessories
I'd guess that Brown being the Earth and 4 other wires for the 2 speakers (L & R), but that still leaves one wire left over?
Thanks in advance,
thepurplepulsar.
Rolla_ball
Light Green - speaker
Blue - Remote power(for amp)
Purple - speaker
Pink - speaker
Dark Green - speaker
Brown - Ground
not sure whether light or dark colors are for + or - green and purple are definitly speakers tho, pink is actually a light purple
however check for a white wire, i think that is for a dimmer, hook that one to ur lights
there may be a mute wire there too, just seal it off, i think its for a handsfree kit somehow
SIKUNIT
The original stereo or the owners manual didnt have a wiring diagram??
I'd recommed running your own earth for the unit, ground it straight to the body.
As for the speaker wires, it's almost always easier to run new wiring, the factory wirng isnt much chop when a bigger wattage speaker is installed anyway.
Scuzzy
http://www.installdr.com/QuickWiring.html
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
The Gray and the Blue/Silver matches this document, I'm guessing this will be your best bet if someone's removed the connector at the end of the loom.
thepurplepulsar
Doesn't matter, I worked it out myself.
Admin you can deleate this thread.
