23rd December 2006 - 05:25 PM
My girlfriend has an 88 Nissan Skyline R31 Ti, that will start cold and and once it reaches running temprature it stops and won't start again until it cools..fuel pump is pumping fine, i have replaced the head with a re-co head, head gasket, water temp sensor, tryed another ECU, another inlet manifold with all new idle steper, fuel preasure regulator air regulator and all but still it keeps on doing the same thing.. im thinking now oil preasure sender.. any feed back would be really appreciated cheers Chris.. -------------------- WHEN IN DOUBT SIDEWAYS WILL GET YOU OUT!! :)
321cya
QUOTE(s13rb @ Dec 24 2006, 11:25 AM) [snapback]1280607374[/snapback] My girlfriend has an 88 Nissan Skyline R31 Ti, that will start cold and and once it reaches running temprature it stops and won't start again until it cools..fuel pump is pumping fine, i have replaced the head with a re-co head, head gasket, water temp sensor, tryed another ECU, another inlet manifold with all new idle steper, fuel preasure regulator air regulator and all but still it keeps on doing the same thing.. im thinking now oil preasure sender.. any feed back would be really appreciated cheers Chris.. try the dizzy as the optical sensor (inside the dizzy) is know 4 shittin its self or try the coil oil pressure sensor wont cause that its only 4 the guage on the dash |
cilkorules
i had this same problem i eventually opened the dizzy cap and found that the screw for the rotor buttton was loose and almost falling off... good to have a look anyways, all u need is a phillips head screw driver |
