Full Version: Car Audio Amp Problem
mavo
WHAT IS GOING ON LOL!!
ive got a bit of a problem there is no power going to my amp??
i replaced the fuse?
still no power?
someone help me
mavo
Draven
QUOTE(mavo @ Aug 23 2005, 04:05 PM)
[right][snapback]5300532[/snapback][/right]
Double check the simple things first... have you checked all the connections are good, all fuses are ok, remote wire from stereo hooked up to amp?
Damone
topics merged.
TUN35
As said double check all your connections. If these seems ok then you could of possible of choosen a bad spot to ground your amp. Easy try another spot. Or the remote wire from your deck is doing nothing. Run a bridge wire from the 12 constant on the amp to the remote to see if the amp powers on. Do not continue to run your amp like that... test measure only and you'll end up with a dead battery.
If your not confident enough with this stuff get someone around who is! Otherwise take it to a professional smile.gif
Also i hope you didn't replace the fuse with one larger than was in there. Never replace with a larger as you can very easily ruin your amp.
