OK this is a Description on How to Flush ur auto trans Fluid
To tell u can do this look on the bottom of ya radiator u should have to hoses going to ya gear box or for some with external auto fluid coolers .......
OK first thing u need is section of hose and a brass joiner ,hose should be no less then 1 foot ( makes life easy)
a Bucket of some type ( note once used for trans fluid its kinda stuffed)
and also u will need the amount of fluid which goes in to ya trans
OK first thing is Jack ya car up as high and safe as possible and get it level.......
OK on the box u will have a inlet and out let hose
Pick on and hose cos it dont realy matter
get your extra bit of hose with the brass joiner in it and attach this to the hose whic u have pulled off
then start ur car and leave it in N and the trans fluid will start to pump let it pump till u think its done. usaly when its start to foam the oil thats pushed out its time to stop the car.....
Now double check that all Oil is out by using the drain plug on the Trans pan or somtimes there is a extra drain for a diff........ check in ya users Manual
Now re Attach the hose back to the right sport were u pulled it off
Re fill the trans fluid till it hits the cold mark on the dipstick then start ya car and run it up and down gears for a good minute thenre check to make sure its is showing on the dipstick......... then run the car till the thermo fans kick in then then re check and top up where needed
Now go back and repeat the draining and then RE-FILL
and check all fluid is up and at the correct levels..... if its over full then drain it at the trans Pan and fill it up right dont just think " Oh is kool No Big Probs" cos dam ur so wrong........ and if ur stupid to do ity then u deserver the costly bill
Now If u dont feel confident in doing this then by all means DONT DO IT
I feel i have given decent instruction on hwo it should be done
If u fuck up and come bitching cos U screwed it all up then dont blame me....... Cos dam Iam a first Year Apprentice and it took me no les then 30mins...
ALL BLAME IS ON YOU WHEN U DO THIS
