I started of with going down to a shop and getting them to cut a 3.5" hole... it only cost me $15 which i think was worth it cause i would have made a mess of it with snips or dremel... the hole came out pretty clean and for $15 im not complaining
After i got the hole cut i headed down to a hose supply place and bought some really flexiable 3" hose and 2 clamps then headed back home to play around... the hose was the most expensive at $22 a metre... i bought a metre even though i didnt need it... im sure i will find something to do with the offcut... vents to disc brakes perhaps?
Well... this is what i started with... u can see the hole i got cut out... and if u cant... ur blind
next up was fitting the hose to the pod to make sure it was going to fit and stuff
i took a bit of spare vacumme hose i had laying around and sliced it down the middle and put it around the hole just so it didnt cut into the pod or flexi hose
next i fed the filter up through the hole with the hose attached to it... i then realised that the pod was too long... *read 30cm pod
i attached the pipe to the turbo and clamped it on... made sure everthing was tight and secure
as u can see... ive put the plastic covers back on but cause the pod was too long it didnt fit back correctly so i drilled some holes in the plastic and ran some cable ties through it... this should stop most of the rain and stuff getten in there
in this shot u can see that its tucked away pretty good and cant really be seen unless u get down on ya hands and knees
so there ya go... done it all for about $30 and the car feels alot stronger now so im cheerin!
Petey
