Full Version: How To Cleans Your Paint With Clay
king of the concrete jungle
This step No.3 in the step by step guide to maintaining your cars appearance, using OFF THE SHELF products only. There are far better products on the market, however they can't be purchased at automotive outlets.
CLEANSING YOUR PAINT WITH CLAY
Recommended Products:-
user posted image
3M Perfect-It III Cleaner Clay**
1 x Hand Held Spray bottle either filled with water (cold) or some Johnson & Johnson Baby Shampoo mixed with water
OR
Meguiars Final Inspection
Please Note:- ** 3M Products can be purchased at numerous locations all over Australia. Please check the Yellow Pages in your area for stockists
Every car finish shares a common enemy: pollution. It relentlessly pursues your car from the second it leaves the factory until your car meets its ultimate demise. It's in the air we breathe, it's on the roads we drive, and it attaches to your car's paint, where it bonds and begins a process of oxidation.
When contaminants get a solid grip on your car's paint, washing alone may not be enough to remove them. Pre-wax cleaners also may not be able to exfoliate large particles. In this case, you have two choices: use a polishing compound, which removes a lot of paint material, or use a clay bar. Clay isn't a polish or a compound, it is a surface preparation bar that smoothes the paint and exfoliates contaminants.
USES FOR CLAY:-
Clay is not a cure-all or a replacement for polishing. It's a tool for quickly and easily removing surface contamination.
One of the many reasons for using clay is the removal of brake dust. Brake dust contamination, which attaches to painted rear bumpers and adjoining surfaces, is a metallic surface contaminant that can be removed safely and effectively by using clay.
Clay is also very effective on paint over-spray. If the over-spray is particularly heavy, you may want to seek the assistance of a professional. Tree sap and tar specks can also be safely removed with a clay bar.
Recently, I have also started using clay on my windows (exterior) to remove heavy road film, bug deposits and water spots. It works very well, and seems to outperform even the best window cleaners.
EVALUATING YOUR PAINT:-
How do you know if you need to use a clay bar? After thoroughly hand washing your car, feel the surface of your car's paint. Do you feel bumps and rough spots? These bumps are contaminants attacking the finish of your car. Removing these surface contaminants (road tar, acid rain spots, bug residue, paint over-spray, brake pad dust, hard water spots, etc.) will improve both the look and health of your car's paint. By the way, you can magnify your sense of touch by inserting your fingertips into a sandwich bag or a piece of cellophane.
No matter how well you hand-wash your car, many of the contaminants that have worked their way into your car's paint finish will remain. Have you ever looked at your foam wax applicator pad after applying a coat of wax? What do you think that black stuff is? It's dirt, and you're waxing over it, sealing it in.
CLAY SAFETY:-
Detailing clay isn't new. Paint and body shops have been using it for years to remove paint overspray. Clay is fairly new to the car detailing market, and is very new to the consumer on retail shelves. In the early days there was always a concern that paint damage might occur if improperly used.
New technology detailing clay bars are made of fine polishing particles in a soft, malleable "clay" medium that allows the bar to be formed and kneaded. Some clay makers add color to make the bar more attractive or to identify bars of differing strength (coarseness).
Many clay products claim to contain no abrasives. This is stretching the truth. The reason clay manufacturers claim their products don't contain an abrasive is because the general public thinks the word "abrasive" refers only to aggressive, paint removing materials. The fact is that the abrasives in most automotive clay products are so fine that you will not see any reduction in paint gloss. After several uses, paint luster may even improve.
Still, I have heard some horror stories about people ruining their cars paint job using a clay bar. I can see how this might be true if an inappropriate product was used or if the clay bar is used incorrectly. It's not hard to use, and feels very much like Blue-Tac or even sticky Playdo.
USING CLAY:-
Using clay is very easy, but you must follow the instructions. Use clay incorrectly and you will create a mess or scuff the surface of your paint.
Before using detailing clay, you must thoroughly clean and dry your car to remove any loose dirt. Direct sunlight should not fall on your car's surface, and it's best if the work area is relatively cool to prevent rapid evaporation of the clay lubricant.
Flatten your detailing clay into a flat waffer that will fit comfortably in your hand.
To use the clay bar, you spray a lubricant on a small area of your car and rub the clay back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Clay is fairly sticky and cannot be used dry. Try using clay dry and you'll make a big mess and scuff your paint.
After a few passes with the clay, rub your hand over the area you cleaned to check for areas missed. You should feel a distinct difference between the areas you have clayed and the areas you have not clayed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft microfiber towel, and buff to a nice luster. Just like waxing, work in small areas.
When your clay is flattened into a nice wafer, you spray both the clay and the paint with clay lubricant and rub the surface lightly with the clay. Three or four passes over an area is normally enough to do the job.
An alternative to spray detailing lubricant is good old soapy water. Be sure to rinse your wash mitt thoroughly and use a fresh bucket of soapy water, not what's left over from washing.
Check the clay bar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint. If you drop your bar of clay on the ground, it's history. Toss it out. Don't take any chances, discard the clay bar if it becomes impregnated with grit. Read the manufacturers' directions for the number of uses of their clay bar. Do not overuse a clay bar.
When you're finished claying your car, you should wash it to remove the lubricant film, then go over it with a pre-wax cleaner to finish cleaning the paint. Finally, seal your freshly cleaned paint with your choice of wax or sealant.
After claying one or two body panels, your clay will begin to look dirty. Don't be alarmed, that's just the clay doing its job. Flip the clay over and use the other side. When both sides are dirty, remold the clay into a ball again and flatten to reveal a clean surface.
OTHER USES FOR CLAY:-
Clay isn't just for paint. You can use detailing clay on any smooth, hard surface, including glass and chrome. Do not use clay on clear plastic, such as headlight lenses.
When I can no longer remold clay to get a clean surface, I use it on my windows. The dirty clay will not harm glass, and it's amazing how much dirt film clay can remove from your exterior glass windows.
I also use my old clay to clean wheels. Clay will safely remove stubborn, embedded brake dust, tar and road film from all factory wheels. Clay is not recommended on wheels that do not have a factory clearcoat or powder coat finish.
With just a little effort, stubborn brake dust that even the strongest cleaners won't remove comes off with detailing clay.
CLAY FACTS:-
Here are some common questions and answers in regards to clay usage:
Q1. I dropped my clay on the ground. Can I still use it?
A1. The safe answer is no. Clay will pick up small particles of grit from the ground that will scratch your paint.
Q2. If I use clay do I still need to polish my paint?
A3. Yes. Clay will not remove swirl marks, scratches or etching from acid rain or hard water spots. Paint polish is still required to remove these paint defects. If your paint is new or like-new, detailing clay will significantly reduce the amount of polishing required to keep your paint in good condition.
Q3. What is the best clay?
A3. What label do you like? There are only a couple manufactures of clay, and the technology is protected by U.S. patents. Clay is manufactured with different levels of abrasiveness and colors to suite different applications. There are some subtle difference in technology (plastic vs. elastic material) and the firmness of the material. In general, softer clays are safer and easier to use. A firm clay cleans better with a little more risk of scuffing or scratching. I prefer the 3M clay bar as it is very sticky and works easily to remove surface contaminants. I have found the Meguiars and Mothers products simply not sticky enoughand require very repetitive going overs to remove foreign objects and still doesn't remove all.
Q4. Is it better to use soapy water or a spray lubricant?
A4. Both work equally well. If you want to do the job fast, use a bucket of soapy water. If you want to work inside or do a thorough job, use a spray lubricant. With a spray lubricant you can wipe down each panel as you go and feel for areas you missed.
Q5. How do I store my clay?
A5. If your clay did not come with a re-usable plastic container, store it in a plastic Ziploc bag.
Q6. Will clay remove my wax?
A6. In most cases, clay will "scrub off" wax protection. Some paint sealants are hard enough to withstand being cleaned with clay, but most are not.
SUMMARY:-
Automotive paint cleaning clay offers many advantages in the removal of surface contamination from paint. Even in the hands of a first-time user, clay is safe and easy to use. Sure, if you use a dirty clay bar, scratches can result. However, compared to machine buffing, compounding, or using harsh chemicals, clay is safer, faster and easier.
zilla
i did this yesterday (with a different brand tho)
makes a HUGE difference, oh so smooth afterwards.. combined with a polish and wax the difference is outstanding!
stands out alot more on darker cars ive noticed tho.
bkerr
ahaha we did this yesterday but literly with clay, we got bogged haha
35NIK
i NEED this stuff, i got over spray all over my roof and bonnet. how much would a detailer charge to do this???Iam lazy!!!
KE_70
car deatilaers use this befor paint protection
