Full Version: Rb30et
Festaonline
WANTED
RB30 Turbo manifold with or without turbo....
Computer to suit same motor application....
Or can i get the stock one remapped if anybody knows pls??...
Cheers
Stable
I dont think you can get the computer remapped.
Have a look around on www.calaisturbo.com.au forums. Prolly the best resource on RB30's.
VLCT WALKY
richo has a auto turbo computer, i will check and see how much i want for the exhaust manifold injectors inlet manifod and cross over pipe!
Probably around the $500 mark, let me know how much u are interested in paying and work from there!
Festaonline
already looked at calaisturbo they aren't tat many stock manifolds but i will keep my eye out and VLCT are they the stndrd injectors or would ya put the gtr injecters and yeah i will summise my funds and see but i would start the bidding at $350 and go from there i am sure we can some to something
VLCT WALKY
nar that would just be the standard turbo injectors
u ant the GTR's would be another 250
Normally they seel complete top conversion,
Exhuast manifold
Turbo
Crossover Pipe
Inlet manifold
injectors
and plumbing "oil water lines"
for around $1500
I don't have the turbo T3 anywhere from $200 2 $500
or the water/oil lines (no idea how much they are)
u do have a series 2 block don't u?
VLCT WALKY
$400
Inlet manifold with everything, x over pipe and exhuast manifold?
let me know
Festaonline
ok will check the finances and get back to you it mite be a few weeks yet though ...
NVthisVR
Yep gotta Turbo auto computor. 12 month old, $100..
BEAST MASTER
pity it's a manual...
NVthisVR
QUOTE(VLCT WALKY @ Apr 4 2005, 03:49 PM)
richo has a auto turbo computer[right][snapback]5039732[/snapback][/right]
Ummm ok must of missed the manual bit!!!
BEAST MASTER
No he just didn't say anything....
Festaonline
it is true i failed to mention that i have a manual and its all going in a R31 skyline too .... someone offered me a man comp for 200 but i am tryin to beat that price down ...... hopw much difference would a man vs auto comp do anyways if fitted to the car??
supertiva
festa... go to your room *hangs head in shame*
QTRMILE
QUOTE(Festaonline @ Apr 7 2005, 05:05 PM)
[right][snapback]5046174[/snapback][/right]
You can use an Auto ECU in a Manual VL with no ill effects... the only difference is they run a little bit more timing advance, if anything it might make it go better!
Festaonline
ok thanx qtrmile i hope that it does work then have to get turbo lol
wonder what i can do to decomp the motor i run at 9.5 compression and have been told that will be fine by a few plp that i have talked to mechanics and all...
any other info would help a great deal thanks.....
QTRMILE
You should be able to get hold of a set of low comp pistons for it pretty easily... and i'm also pretty sure you could find a cyl head with larger combustion chambers... they come in two sizes 66cc and i think the other is 77cc or thereabouts. As far as i can remember the lower comp heads were fitted to the "Holden" RB30, while the 66cc head was fitted to the Skylines.
If i were you i'd definetly look at reducing the compression... 9.5 might be OK down south where it's cooler, but up here it's a recipe for disaster...
Festaonline
yeah thats what i thoughth well i am going to source another head anyways and get the chambers taken out to drop it and the pistons come later as i am only lookin at about 8lb boost anyways and will keep an eagle eye on it gauges fom there .....
thanx
