king of the concrete jungle
Mar 21 2005, 10:02 AM
Yeah that's fine and normal. I'd just be draining the oil (engine, gearbox, brakes and power steering) and using fresh stuff since its sat for so long as a precaution, and also the fuel if it's been using the PULP and has some considerable amount left in the fuel tank as it can go "off" and cause fuel issues. When you do that then give it a good long hard drive as the computers do learn your driving style and it will oeprate far better with a good hard run (within reason of course)
QUOTE(*TiMy* @ Mar 21 2005, 09:45 AM)
yer it is the 3.8l v6 motor it drives fine started third go wich isnt to bad considering it hadnt been drivin in a year so it should be alrite?? ill just get autoleaders to have a look over it aswell. cheers man
[right][snapback]5017133[/snapback][/right]
