Step 1.
Undo bolts on swaybar “D clamps”
http://www.boostcruising.com/database/techarticles/files/greg_ta22200502181051techarticlesfile1.jpgStep 2. While holding a spanner of socket on the bottom bolt of the swaybar end link, undo the locknut at the top. Then remove the top nut and slide out the rod. Take care to note the order of the bushes, washers and spacer.
Step 3. Remove the old bar.
Step 4. Grease up the new “D bushes” and clamps, and install onto new swaybar.
Step 5. Perform the reverse of Step 1, then Step 2. Remember not to over tighten as the bushes will be squashed out of shape and will not perform properly. Your new shiny swaybar is now installed.
http://www.boostcruising.com/database/tech...ticlesfile4.jpg
The End.
