Nath-90
Nov 6 2009, 10:44 PM
ok, so i have my main things now, the block, head, sump, intake etc.
wanting these as i either dont like the current one or dont have it/them:
Flywheel, stock, lightened etc, whatever u have
turbo manifold, stock one is fine
t28 turbo, pref with oil and water lines
full gasket set (doubt anyone ust happens to have one but hey, worth a shot) incl HG, seals for everything from rocker covers to injector o-rings.
bosch 044 fuel pump, or a vl turbo fuel pump
Intercooler, looking for a medium-ish sized one, 600x300x60 or so, pref 2.5 inlets.
I/C piping, straight bits, bends, 2.5 or 3 inch would be fully sick bru.
good cond or new ca18 engine mounts
other:
s13 coilovers with hubs, knuckles, rotors, etc, good nick but not too picky...
s3 r31 front bumper, may have one lined up with an I/C hole cut(lawler) but will look at whats around, not interested in kits or anything, going for stockish look if i can.
2.5-3 inch r31 exhaust from cat back.
basically if sum1 has a whole spare engine with a blown HG or spun big end etc, i'd consider buying it on the cheap for spares or for the bits i dont have.
Can't guarantee i'll have cash on the spot to buy as this is going to be a slow uild, wanting it to be finished by april 2010 though so once it gets going it should keep going pretty quickly.
Cheers!
4g32turbo
Nov 6 2009, 11:01 PM
ive got 2x 90 degree ali intercooler pipes in 3'.
gordie
Nov 7 2009, 07:26 AM
stock turbo exhaust manifold $50.
s13 lca's, knuckles, rotors, calipers with pretty much new pads, think i have brake lines too. $300
Nath-90
Nov 7 2009, 08:09 AM
assuming thats an fr manifold gordie i'll take it tonite! Wil let u know bout the s13 stuf!
gordie
Nov 7 2009, 08:11 AM
yeah came off my s13.
Nath-90
Nov 7 2009, 08:56 AM
sweet, pm address, can grab tonite after 6pm
gordie
Nov 8 2009, 08:08 AM
dont think my pm's that i send are working for some reason.
try pm'ing me your number. home all day if you wanna pick it up.
Nath-90
Nov 8 2009, 11:37 AM
shld b there today some time mate
gordie
Nov 16 2009, 09:02 PM
still want the manifold?
Nath-90
Nov 16 2009, 09:07 PM
not right the moment, will do soon though, gotta budget between living comfortably or living poor and working on car stuff
reddo
Nov 17 2009, 04:42 PM
got a flywheel here, bog stock i think, however i might be lightened... ill check, has a good HD pressure plate, and also a clutch.... let me know and i'll take happy snaps..
Nath-90
Nov 17 2009, 04:46 PM
definitely keen mate! Where u at?
rocco-s13
Nov 18 2009, 10:02 AM
i have a standard CA18DET head gasket brand new still in wrapping,
it's an AJUSA brand apparently will do the job fine, i brought a complete gasket kit and did not use this as went metal headgasket.
$50 big ones
let me know if you want it PM/message or mobile 0448 728810
also depending on how budget your set up is going to be i have a cut down truck intercooler that was on a mates 300rwkw rotary and cooled it fine, can have for $50 also and can get pics if needed. 2.5" inlets from memory but would need to check.
ROCK ON
