WizardHat
Nov 4 2009, 01:01 PM
Hey guys,
I seem to be having an issue with my Pulsar (89' S2 Q 1.8LE), this morning as I was driving home the ECM light switched on, but turned off after about 15-20 seconds. About 2 minutes later, the same thing.. though the ECM light stayed on for longer.. maybe 1-2 mins? this continued until I arrived home.
One I was home I checked the ECM for fault codes, it flashed code 21.. which would indicate that the throttle position sensor voltage is too high. That's a push in the right direction for sure, but where do I go from here on rectifying the problem?
I need the car to get to work tonight, so would like to possibly have it rectified by tonight.. any help is greatly appreciated.
Cheers,
Kane.
iamhappy46
Nov 4 2009, 09:50 PM
The problem is most likely the TPS needs adjustment, however it would be fine to drive as too high is better than a low voltage for the TPS
At the most, you may be up for a new TPS sensor
WizardHat
Nov 4 2009, 11:03 PM
Okay so it should be fine to drive even though the ECM light is still on constantly?
Took apart the throttle body tonight and gave it a good clean, got rid of all the carbon and cleaned the area around the sensor.. it idles a lot lower which is good but yeah, the ECM light is still on, though the ECM is now showing no fault code in diagnosis mode?
iamhappy46
Nov 5 2009, 06:04 PM
The ECM has logged a fault so light will remain on intermittently until cleared(battery disconnected or ECU fuse pulled etc)
WizardHat
Nov 5 2009, 11:00 PM
It's all taken care of now, took the throttle body off again today and gave it another clean, ended up picking up a new TPS and intake hose for $10, all installed in less than 10 minutes and reset the ecu, now no problems at all. Re-adjusted my clutch while I was in there, car now runs better than when I bought it.
Thanks for your help champ!
