matty_lenon
Nov 3 2009, 08:39 PM
hey guys, wondering about installing a ps2 in my 01 vx commodore.
just a couple questions
would i need to add another battery or would running a massive inverter be fine?
has anyone done it and how did it go?
also i was told this would it work:
Get a power inverter and wire the positive wire straight to the battery. You will need a small fuse to go between the wire and battery. Then wire the negative to a uncovered metal part in the car. See how much power the ps2 draws before you get a power inverter.
also i have a double din lcd flip out head unit... would i just run the three coloured cables from the ps2 to the screen.. ie. the red/white/yellow ones? video/sound/ or something?
any help would be appreciated! thanks
slammed sv6
Nov 5 2009, 03:42 PM
i cant say that i have done a ps2 i was going 2 do a xbox 360 and yes you do need a power inverter with wire runing to the battery then just earth it to the car make sure it has no paint on it however you souldnt need a 2nd battery
yes you do just need the red white and yellow rcas runing to the headdeck on the aux in hope this helps
LUXPSI
Nov 6 2009, 09:45 AM
You shouldn't need to get an additional battery...
You will need a DC to AC converter. This little converter changes the electricity that your house uses into the type your car battery uses for the PS2.
Earth it all then just connect your RCAs (red/white/yellow) just like you would if your PS2 was connected to a TV.
wooley
Nov 6 2009, 09:59 AM
DONOT runt he positive to the battery what ever u do we just used one that plugged in the ciggy lighter worked fine
Protius
Nov 6 2009, 05:57 PM
QUOTE (wooley @ Nov 6 2009, 09:59 AM)
I would hope that you upgraded the wiring to your cigarette lighter then because it won't last too long! They can handle about 10A and I'm pretty sure a decent inverter will draw more than that.
wooley
Nov 6 2009, 05:59 PM
ran a full 30 amp wire to it thats what the auto lecy said to
ZCH91
Nov 10 2009, 06:28 PM
QUOTE (wooley @ Nov 6 2009, 05:59 PM)
You're obviously mistaken bud. Why on earth would the sparky tell you that running a 30amp (capable) inverter thru a wire that's rated at 10A (your cig lighter circuit) ??
Re-think that hey?
triss
Nov 14 2009, 02:47 PM
QUOTE (ZCH91 @ Nov 10 2009, 06:28 PM)
Re-think that hey?
no i think he ment that he upgraded the cable goin to the ciggy lighter from 10A to 30A which makes more sence... but then again how much would a ps2 really draw... like 3-4A max?
