calvo_808
Nov 2 2009, 02:44 PM
just trying to find the best set up dont really know which to run
motor is standard apart from rocker arm stoppers,
what should i run?
Cheers
Calvin
Nov 2 2009, 03:07 PM
stock clutch fan or if your keen on something slightly upgraded track down rb25 clutch fan (slightly more aggressive fan fins/blades)
thermo's are quite ordinary unless you put quite alot of effort into a custom surround or find oem type thermo's such as AU falcon that have a surround that is easily modified to fit
Nov 2 2009, 08:42 PM
thermo will let more of the power from the motor make it to the wheels, alot of ppl just use the stock air con fan
calvo_808
Nov 3 2009, 06:19 AM
QUOTE (delazy @ Nov 2 2009, 04:07 PM)
do i need the whole clutch set up or just the fan?
Nov 3 2009, 06:22 AM
QUOTE (calvo_808 @ Nov 3 2009, 07:19 AM)
whole clutch setup...the fan bolt holes are different from memory...saves some stuffing around anyways...
should also bolt in using the stock radiator surround...so no need to trim any of it
calvo_808
Nov 3 2009, 09:08 AM
where would be the best place to pick one up?
spg?
Nov 3 2009, 09:22 AM
QUOTE (calvo_808 @ Nov 3 2009, 10:08 AM)
spg?
yeh, go see ben and see wat he can suggest or get for you.
tas_ae71
Nov 3 2009, 09:34 AM
the HP loss from the clutch fan is prob similar to the HP lossed rom the altenator when the fan has kicked in.
also cheap/pov fans dont flow much, a shroud isnt difficult to make.
best thing to do if you do go that way is to set-up a automatic on/off. i had one on a switch in my corolla and it was a bit of a pain at times. i would forget to turn it on in traffic etc lol! never needed it at 60kays+ tho.
tas_180
Nov 3 2009, 10:37 AM
Keep the stock clutch fan & shroud Calvin. Any power gains by using thermos are sfa, especially with the low level of modifications the car will have when it runs.
If you need any further bits (besides the bits I have here for you anyway
), just drop in or call me on 62741506.
Ben
caelum_s13
Nov 3 2009, 11:55 AM
so im assuming the old girls getting the DET treatment?? very jellous, wish i just bit the bullet and did it while i owned it.
tas_ae71
Nov 3 2009, 12:00 PM
QUOTE (caelum_s13 @ Nov 3 2009, 12:55 PM)
someone TRIED to tell you to get a half cut instead of rebuilding the boat ancor n/a pos...
caelum_s13
Nov 3 2009, 12:11 PM
haha indeed you did...oh well oneday i may own another...and it will be det.
calvo_808
Nov 4 2009, 07:49 AM
yeah dropped the new motor and box in on monday night
Click to view attachmentcheers ben i should be in some time this week i reakon
thanks guys
Calvin
