Full Version: Toyota 2l-t Boost Increase
Boostcruising.com > Global Club Discussions > AU: Tasmania
Juddie
In 85 Bundera, has just had diesel pump screwed up for more fuel, has 2.5" right thru, snorkel etc, 120k's on rebuilt turbo and engine, whats a safe boost increase on something like this, was thinking 3 or 4 psi?
HSV_587
http://www.4wdmonthly.com.au/forum/
Jump on there....heaps of good info....
The main issue is increasing engine temp when raising boost on the 2lt....
They never had a good cooling system/head design.....
Juddie
cheers mate
CKY767
ah dont worry about it Juddie, wind it right up smile.gif see if you can get it to do wheelstands laugh.gif
reddo
I'd place an EGT gauge into the manifold, and start knocking the boost and fuel up slowly. Most of those motors can take up to 12psi and still haul well, however, check your research.
4wd monthly is good, but if you want the best forum for 4wds, cast your eyes over
www.outerlimits4x4.com
but go easy, use the search button, and then if you really cant find what your after, then ask the question.
and the toyota section.
