fasr32
Oct 25 2009, 05:13 AM
hey got a r33 series 2 wen putting my foot down it will misfire and not go anywhere just keep jerking, it will also stall wen going up a hill or stopping, ive done
afm
02 sensor
injectors
fuel pump
fuel filter
plugs
icv
tps
checked coilpacks i dunno if they are ok tho
i dont kno wot to do
pipster11
Oct 25 2009, 07:45 AM
will be coilpacks
you can use high temp silicone from bunnings ($10 for a bottle/can) and seal them up to stop them arcing out but its only temporary so your best off getting some jjr coilpacs or splitfires if you have the cash
Rancher
Oct 25 2009, 10:09 AM
QUOTE (pipster11 @ Oct 25 2009, 07:45 AM)
will be coilpacks
+1
You're using electrical components that are 16yrs old. They were never designed to last that long.
35NIK
Oct 25 2009, 09:49 PM
coilpacks are only designed for 80,000km's. Thats when nisssan say replace them in a logbook service...
But mine are going strong at 160,000km. im replacing mine soon.
Josh
Oct 25 2009, 10:03 PM
+1 for coilpacks plus check ignitor too
fasr32
Oct 30 2009, 09:15 PM
new coilpacks on there way hopefully fixes it
iamhappy46
Oct 30 2009, 10:00 PM
If it is jerking as it comes onto boost, also check for boost leaks.
fasr32
Oct 30 2009, 10:58 PM
where do i loook for boost leaks intercooler piping and where else
iamhappy46
Oct 31 2009, 12:12 AM
Anywhere between the turbo and the throttle body
E30_luv
Oct 31 2009, 03:25 PM
Fuel pump relay possibly, I know thats the same response that happened with my brothers car when his was gone. And similar to my old car when the relay went on it aswell.
fasr32
Oct 31 2009, 08:22 PM
brand new fuel pump jus put in it tho
97caprice
Oct 31 2009, 08:59 PM
QUOTE (fasr32 @ Oct 31 2009, 08:22 PM)
Check for boost leaks first before randomly throwing parts at it, they will cause ahesitation,not a miss as iamhappy thinks. They will also cause it to stall while coming to a stop. What have you got the plugs gapped to?
fasr32
Oct 31 2009, 09:06 PM
plugs are normal .08 or woteva they come as how can i find the leaks is there a easy way plus the intercooler piping joins are a bitch to get to as i gotta take front bar off
97caprice
Oct 31 2009, 09:13 PM
QUOTE (fasr32 @ Oct 31 2009, 09:06 PM)
I use a boost leak tester, but you can use a cigar(lots of smoke) and run it all around the hoses everywhere. If there is a leak, with the engine at idle it will suck the smoke in.
HR31 PASSAGE
Nov 1 2009, 05:04 PM
does it idle fine?
but under load driving when it hits boost cuts out right?
i just had the same issue & my fuel pump was clogged check that mate or coils i got some spare parts here you could swap over to see the issue if ya want...
good luck just pm me if you need anything......
patrickd79
Nov 1 2009, 07:48 PM
Is it ok if I ask a question here? Yesterday I was test driving a skyline and the car drove perfectly until i hit 4500rpm then it more or less cut out, ran like a dog and wouldnt rev any higher. Any ideas what that might have been?
pipster11
Nov 2 2009, 09:03 AM
that would be coilpacks probably
BuC|<3t-H3@d
Nov 2 2009, 01:53 PM
a mate of mine had a skyline that did the same thing (cut out at 5g) and not sure why, but it was the boost controller, pulled it out and she ran fine
fasr32
Nov 2 2009, 07:05 PM
done fuel pump injectors and filter tho
iamhappy46
Nov 4 2009, 10:01 PM
QUOTE (97caprice @ Oct 31 2009, 09:13 PM)
Most boost leaks occur when the hose clamps tension up under boost and allow the silicon or rubber hoses to not seal to the intercooler piping. Under vacuum, the silicon/rubber will happily seal to the piping. Its like a garden hose with a small cut in it, might dribble a little fuel watering the plants but block off the flow at the nozzle and suddenly you have a geyser of water pressurising out
I prefer to watch the air flow meter voltage spike and timing drop on a scan tool to confirm though but its a common problem
QUOTE (BuC|<3t-H3@d @ Nov 2 2009, 01:53 PM)
Less boost means usually means the hose clamps dont strech as per my above reason
fasr32
Nov 4 2009, 10:27 PM
anyone got a tool to cheack for vacuum/boost leaks ill pay to come out and check piping sms me or pm me
BuC|<3t-H3@d
Nov 5 2009, 04:14 PM
QUOTE (iamhappy46 @ Nov 4 2009, 11:01 PM)
ran same boost with and without the boost controller, yet it had the problem with boost controller and no problem when it was out
fasr32
Nov 7 2009, 03:12 PM
put new coilpacks in still going to stall wen slowing down at lights etc the sputtering has gone away mostly tho
fasr32
Nov 7 2009, 06:35 PM
got told could be comprssion i fuking hope not
fasr32
Nov 7 2009, 09:15 PM
tried another ecu that didnt do anything so i dont know ? fuked turbo? low compression? boost/vacuum leak? thats all i can think of
iamhappy46
Nov 7 2009, 11:21 PM
Your time looking for boost leaks is a lot cheaper than the other two options. Rule out boost leaks before you go for the expensive options
fasr32
Nov 8 2009, 12:05 AM
anyone kno how to test boost leaks and check compression
Mosquitocoil
Nov 8 2009, 10:39 AM
What boost you running? Could be boost cut... or coilpacks like everyone else has said.
fasr32
Nov 9 2009, 06:24 PM
stock boost got brand new coilpacks
iamhappy46
Nov 9 2009, 07:41 PM
Go through every single hose clamp and tighten them all down again. Check all silicon hoses for damage or splits.
fasr32
Nov 9 2009, 11:03 PM
i need new clamps mine r shit
