QUOTE (Felix_TRX @ Oct 19 2009, 08:52 AM)
Lazy, a R31 diff needs shortening. It has been looked into before, and locking a S3 diff is much easier and cheaper. Or be like me and have a H190 LSD imported for $1500. And as for the cost of it Lazy, a lot more people sling other diffs under Toyota's than they do for 910's. Supply and demand. Less demand for 910 diff swaps, less people do them, those that do charge more for it.
A S13 is IRS, 910 Bluebird is live axle. I believe the S13 gear can be fitted because the Aussie 910's still have the mounting points from the Jap IRS 910's in the floor pan. It's a big job though.
Cheers, Greg.
yeh right, well they run r31 diffs in ae86s without shortening them, just limits you to 8j wheels and nothing wider unless you flare guards. Id have thought bluebird wheelbase would have been wider.
At the end if the day a jig is a jig, from scratch ive seen ppl charge $700 to weld on mounts, id have thought r31, spool and converted would cum in sub $1500 and stronger with better gearing options? Running an sr20 or similar im sure the extra track would go astray anyways
