$Tommo$
Oct 17 2009, 12:00 AM
I installed a tacho in my '88 hilux but the ignition system sends a double pulse i think so the tacho doesn't read correctly.
Does anyone have any solutions to this problem or has anyone encountered this problem and found a way around it??
Thanks
Tom
$Tommo$
Oct 18 2009, 07:45 PM
come on... anyone with ANY information would be greatly appreciated, surely someone has a tacho in an early hilux..
Thanks
$Tommo$
Oct 24 2009, 09:41 AM
35 views and nobody has ANY information...
comon guys, surely someone has put a tacho into a hilux??
wooley
Oct 24 2009, 09:58 AM
which side of the coil did u wire to if its on the wrong side then it will do this..also on the off chance you r hilux doesnt run a double coil?? i remember in my pintara when we wired the tacho up that i had to run it to the secon coil for some reason
mr031
Oct 24 2009, 10:14 AM
you need a vdo ratio box, it modifies the signal to suit as its adjustable, and pricey lol
Italia_85
Oct 25 2009, 09:52 PM
look up on internet, to correct on wiring pin for fitted on tacho.
WoodStok
Oct 26 2009, 05:21 PM
perhaps there is some type of diode or resistor you wire inline to reduce the pulses by half? try looking on a hilux specific forum and you may find a better answer.
