QUOTE (m.o.d.aus @ Oct 14 2009, 10:43 PM)
Its common that 600 will beat 1000's from 0-150 or there abouts.
As the power to weigh ratio is better.
But most 1000 will pull back after that as the 600 run out of puff so to speak.
But thats just a general thing.
Hence why 600 are better street bikes as they will beat anything to the speed limit
get off the drugs mate.. it's pretty obvious you have limited knowledge of bikes.
___________
as for cornering, due to the extended length of a 1000cc (fork rake, and swingarm) and wider rear tyre results in a slower change of direction. a 600 won't corner harder or faster, it only has the advantage in consecutive direction changes. fit a 180/55 rear tyre to a 1000 and there goes that advantage.
