Full Version: Sub Cutting Out
<3 slideing
fixed
Gain is turned up too much, power leads too small, bad grounds, etc.
<3 slideing
QUOTE (the_random_hero @ Oct 2 2009, 10:49 PM) *
gain was turned up high
power leads look like normal audo barn crap
ill change how its grounded
truffles
Yeah I would double check all the wiring but it sounds like your sub is trying to draw too much power from the amp. Try running the gain and volume lower and check if th problem persists.
synster
are you running 8 gage?
and what is your amp earthed to?
boost101
yeah your cables and earthing are the heart of your sound system there the most important shitty wiring and brands short and or overheat seen many cars alight because of bad wiring
