Full Version: Quad Charged 35
Boostcruising.com > Global Club Discussions > AU: Queensland
trommie
This is probably old news to some, but for those who havtn seen it:
Note: if you have seen it, no one gives a shit so there is no need to comment telling everyone..
The Power Enterprise R35 GT-R Four Charger made quite a statement when it was announced in December. Twin charging each side of the engine bay for a total of four turbines seems like an interesting idea at first glance but the use of Rotorex superchargers called the usefulness of this into doubt.
GTRBlog spoke with Hideo-san from Power Enterprise today at Tokyo AutoSalon where the Four Charger is on display about the realistic side of the Four Charger setup.
Firstly, yes this kit is planned for sale globally so this isn’t just a one off demo car for AutoSalon. So we asked; Why go down the complicated Four Charger route instead of just doing something like an increase in turbocharger size? The answer is found in terms of peak power RPM and the useable power band.
No-one can really say the VR38DETT motor lacks mid range torque, in fact it’s a great lag free drive in many owners opinions. Power Enterprise think it could be better though so making peak power available at just 4,000 rpm (instead of the ~6,000 rpm standard) is there goal. When they say peak power though they’re not referring to the standard 480ps anymore - they mean as much as 700ps!
Yes this kit is being built to produce as much as 700ps in the top specification. At specifications higher than 600ps your standard injectors and fuel pump are not sufficient anymore and such kits will come with replacements for each. In fact all OE parts not up to the task will be replaced by components in the final kit so that customers will not have to shop around for bits and pieces to finish the job. This includes an ECU solution that is said to defeat all known ECU cutouts such as the overboost protection, transmission failsafe cutout, Japanese speed limiters and so forth.
The P-MAP ECU tuned by Power Enterprise for the R35 GT-R Four Charger is said to be able to intercept the relevant signals which cause the GT-R’s ECU to trigger these protection circuits and prevent it occurring. It’s a separate module that is wired into the ECU harness.
The kit will consist of the superchargers, an intake hard pipe kit w/ silicon joiners and upgraded host clamps, CAI setup, a replacement radiator shroud (aluminium most likely), injectors, fuel pump and so on. An upgraded intercooler is also in development.
As for changing the weight distribution of the car with all this gear at the front of the engine, Power Enterprise say the footprint is quite small and that the weight is not a serious concern.
Right now the kit is still in testing so no final dyno charts are available and for this reason Power Enterprise won’t release any official dyno chart. They will however have these available when the kit is completed to their high standards and proven reliable.
Expect all this to come at a price however, an estimated USD RRP of $10,000 - $15,000 dollars.
Nissan R35GTR, VR38DETT, Power Enterprise QUAD-charger system (Stock IHI Twin turbo & Twin Rotrex C30-94 Super Charger: 400ps x2 flow rate, at down stream of intake) as displayed at 2009 Tokyo Auto Salon. The system is designed for 700HP (670+WHP) with huge low to mid-range torque gain benefiting road course and time attack racers. This kit includes, Titanium Exhaust System - highest grade titanium available for automotive market (main pipe 89mm and dual-twin 70mm outlet), reinforced hose & T-bolt kit, and P-MAP (Newly developed piggy-back/Sub-ECU) pre-programmed and programmable to re-calibrate fuel (Air Flow less "D-Jetronics" w/ self learning), IG timing, boost, speed & rev limiter, Additional injectors, Launch control, nitrous and more. The QUAD-charger kit will be tested and tuned to perfection at several of race courses prior to the anticipated release date of April to July 2009. Dyno sheets based upon several courses will be provided for tuners base
mapping.
gtrgodzilla
kick-ass!!!!
Plugg3r
That be pretty deadily, only probably one downfall... Warranty Void, but then again if you have the cash flow to buy one you probably wouldnt worry much about the warranty void.
that's pretty damn awesome. looks complicated, but i guess it's a cokplex car lol
B Unit
Have they fixed the gearbox yet?
180_project
QUOTE (B Unit @ Oct 2 2009, 02:12 PM) *
PPG sells a 1st-gear upgrade if thats what you are referring to.. Retails for about 2.5 g's
Sharpy
QUOTE (180_project @ Oct 2 2009, 02:49 PM) *
lol oh the day when a PPG gearset is cheaper than a front lip
(justjap sell a front lip for a 35 for 5k)
GreekWarrior
goodbye gearbox lol
BWAAAT
Was on motive DVD
trommie
guess the 5k for the lip is still cheaper then the 30k they want for vspec break pads. keep it exclusive my ass
180_project
QUOTE (Sharpy @ Oct 2 2009, 03:58 PM) *
QUOTE (trommie @ Oct 2 2009, 04:51 PM) *
lol, makes the 2.5g's sound like spare change
Also like the titanium bonnet stay for $1000
Buddo_007
that kit sounds good an all but because the 35R is hand built an doesn't have a proper power output coz the all vary between each car how would the generic piggy back be able to cope with different engine's so to speak
i dont mind the new GTR's but they really need to sort out the whole street legal track car with all the function to void a warranty at the push of a button i rekon it's BS
my 0.02C
Sharpy
QUOTE (Buddo_007 @ Oct 2 2009, 11:32 PM) *
my 0.02C
point zero two of a cent?
http://www.youtube.com/watch?v=D2isSJKntbg
