B16A2
Oct 1 2009, 12:38 PM
hey guys well ive never installed a amp in my life
got a friend to do all the wireing for my car
from the battery to the amp and to the sub
now now on the amp i need to know witch wires go where for connection
if somone have diagram??
its a 2channel
btw
LUXPSI
Oct 2 2009, 03:35 PM
So you want to know which wires go where from the headunit?
From the headunit you'll have the remote wire and the RCA's..
Then you have the ground wire from the amp and that's basically everything.
ZCH91
Oct 2 2009, 08:17 PM
Unless you got the amp 2nd hand, you will find the wiring instructions in the booklet that came in the box.
If you did get it 2nd hand and didn't come with such a booklet, google the model number and brand of the amp and you should find it there.
Pretty basic stuff mate
WoodStok
Oct 10 2009, 02:40 AM
also all the terminals on the amp should be labeled with their intended function. if not you should distance yourself from that amp (if it is an amp) as quickly as possible.
