Full Version: Ati 5000 Series..
Damo
omg.. how good does this look..
http://www.amd.com/uk/products/desktop/gra...on-hd-5000.aspx
http://www.amd.com/uk/products/desktop/gra...0-overview.aspx
meant to be 512mb, 1gb, 2gb and 4gb..
Can't wait for 5870x2...definately upgrade to that and new i7 combo..
ATI Radeon™ HD 5870 GPU Feature Summary
* 2.15 billion 40nm transistors
* TeraScale 2 Unified Processing Architecture
o 1600 Stream Processing Units
o 80 Texture Units
o 128 Z/Stencil ROP Units
o 32 Color ROP Units
* GDDR5 interface with 153.6 GB/sec of memory bandwidth
* PCI Express 2.1 x16 bus interface
* DirectX® 11 support
o Shader Model 5.0
o DirectCompute 11
o Programmable hardware tessellation unit
o Accelerated multi-threading
o HDR texture compression
o Order-independent transparency
* OpenGL 3.2 support1
* Image quality enhancement technology
o Up to 24x multi-sample and super-sample anti-aliasing modes
o Adaptive anti-aliasing
o 16x angle independent anisotropic texture filtering
o 128-bit floating point HDR rendering
* ATI Eyefinity multi-display technology2,3
o Three independent display controllers
+ Drive three displays simultaneously with independent resolutions, refresh rates, color controls, and video overlays
o Display grouping
+ Combine multiple displays to behave like a single large display
* ATI Stream acceleration technology
o OpenCL 1.0 compliant
o DirectCompute 11
o Double precision floating point processing support
o Accelerated video encoding, transcoding, and upscaling4,5
+ Native support for common video encoding instructions
* ATI CrossFireX™ multi-GPU technology6
o Dual, triple, and quad GPU scaling
o Dual-channel bridge interconnect
* ATI Avivo HD Video & Display technology7
o UVD 2 dedicated video playback accelerator
o Advanced post-processing and scaling8
o Dynamic contrast enhancement and color correction
o Brighter whites processing (blue stretch)
o Independent video gamma control
o Dynamic video range control
o Support for H.264, VC-1, and MPEG-2
o Dual-stream 1080p playback support9,10
o DXVA 1.0 & 2.0 support
o Integrated dual-link DVI output with HDCP11
+ Max resolution: 2560x160012
o Integrated DisplayPort output
o Integrated HDMI 1.3 output with Deep Color, xvYCC wide gamut support, and high bit-rate audio
+ Max resolution: 1920x120012
o Integrated VGA output
+ Max resolution: 2048x153612
o 3D stereoscopic display/glasses support13
o Integrated HD audio controller
+ Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
+ Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
* ATI PowerPlay™ power management technology7
o Dynamic power management with low power idle state
o Ultra-low power state support for multi-GPU configurations
* Certified drivers for Windows 7, Windows Vista, and Windows XP
Speeds & Feeds
* Engine clock speed: 850 MHz
* Processing power (single precision): 2.72 TeraFLOPS
* Processing power (double precision): 544 GigaFLOPS
* Polygon throughput: 850M polygons/sec
* Data fetch rate (32-bit): 272 billion fetches/sec
* Texel fill rate (bilinear filtered): 68 Gigatexels/sec
* Pixel fill rate: 27.2 Gigapixels/sec
* Anti-aliased pixel fill rate: 108.8 Gigasamples/sec
* Memory clock speed: 1.2 GHz
* Memory data rate: 4.8 Gbps
* Memory bandwidth: 153.6 GB/sec
* Maximum board power: 188 Watts
* Idle board power: 27 Watts
rotor-mad
Now people can play crysis at epic resolutions while watching there 1080p HD porn at the same time.
Chris
The HD5000 series is now availible at UMart.
HD5870 - $600
HD5850 - $400
CALIbrated
QUOTE (Chris @ Oct 4 2009, 08:49 PM) *
HD5870 - $600
HD5850 - $400
i wouldnt go rush out to buy one (ignoring the fact i just bought a 4890). in 3 months time the prices would have come down a bit,and i would like to see the 5890 added to the range before even considering it. no but for those wanting an alternative to the GTX295. its pretty much a no-brainer.
Chris
QUOTE (CALIbrated @ Oct 5 2009, 10:33 AM) *
GTX295 - ~$640
HD5870 $600
I would go the 5870 if i wanted top of the line, but i agree, wait till the HD5890 / 5870x2 or the GTX3xx series, i suspect a significant drop (The GTX3xx series will probably be $700+ though.
Damo
gt300 series would be so over-priced it's not funny..
The 5870x2 will be a monster!!
I'm slowly looking at building a new pc, depending on what the new gt300 series is like, i'd most likely go ati again with some other beastly parts..I just don't see the new gt300 being that special, so far it's just figures nothing has been released for testing..
SK Group
I've got a 5870.
I get P16586 3DMarks
Damo
how much difference have you noticed in gaming and that...
CALIbrated
QUOTE (Chrome-H3 @ Oct 14 2009, 10:16 PM) *
I've got a 5870.
i get more than that with my 4890
SK Group
QUOTE (Damo @ Oct 15 2009, 09:50 AM) *
dunno.gif smooth as fuck at max res and max settings in any game.
