I got a Walbro fuel pump and it flows 250L/h and is good for up to 500hp.
The installation is pretty straight forward. The fuel pump is a direct bolt in replacement for the Nissan OEM pump. In the S15, pull out the carpet in the boot...and the access panel is on the "shelf" that is in the boot. ...
Undo the 4 bolts holding the cover in place - and this will give you access to the breather hose, fuel line, return line and power for the fuel pump. In this pic you can see the power plugs have already been disconnected. Before attemping to remove the fuel lines - its important that you release any pressure inside the fuel system. We depressurised the system by simply pulling off the fuel hose and bleeding it. Or...if you don want the fumes, simply start the engine and drain the fuel system until the engine dies.
Disconnect all the tubes and unscrew the black "locking ring" holding everything down. This is a huge "ring" around the white plastic cover that the hoses connect to. This unscrews anti-clockwise, and you need to be rough with it. We had to do mine by getting a screw driver & hammer, and tapping it undone because it was too stiff to undo by hand. Once you get is undone - you now have access to inside the fuel tank, and to the fuel pump.
The fuel pump is attached to a metal bracket, which is up against the rear passenger seat side of the fuel tank. You can reach in to grab it and pull it out, be careful and move it far left/right to manouvre it appropriately to pull it out, sometimes the fuel float will make it difficult to remove.
Once it is out - this is what it looks like. From the top down, you can see the fuel pump pick up filtration thing, the fuel pump itself attached to the metal bracket, the connecting hose (for pumping fuel) and the associated wire (for power), then the top plastic cover (this is the bit you saw earlier in picture 2)
Here is a comparison between the OEM pump and the Walbro pump.
Remove the old fuel pump (you just unclip it) and attach the new fuel pump. As I said - its a direct bolt in replacement. Attach associated hoses and plugs (you can use the OEM power plug on the new pump - it clicks straight in). Now the fuel pump is ready to go back in.
Then End..
