QUOTE (streetholden @ Sep 21 2009, 04:58 PM)
Hey all, my new motherboard showed up today (Gigabyte P55-UD3P) and att he time i didnt bother looking at sockets, now im stuch with a LGA1156 which is the I5 and I7 chips.
As im only on a budget of $200 a week for this computer i was going to go for the I7 860.
stock is 2.8GHZ, and heard max OC was 3.46GHZ. can it be over clocked anymore? as i only have case and mobo at current time, once i get the cpu i can figure out what DDR3 ram ill be going, most likly the cosair 6GB kits, but buy to so i can fill all 4 slots, then can sell the other 2 sticks and overhead fan.
Whats yoru input and the way to go about this delemer of the CPU?
With an i7, to run the memory in a triple-channel configuration, you need your memory sticks in multiples of 3 (ie, number of physical sticks of equal sized memory) thus you will not be able to fill all 4 slots. If you did, the i7 will run in dual-channel configuration. With the i5, will only operate your memory in a dual-channel configuration thus you only need your memory in pairs.
Overclocking is for jews. The i7 is more than fast enough for games. Spend the money on fast disks as they will increase the 'apparant speed' of your computer. CPU/Memory is so fast now days that the biggest bottleneck on the PC is your hard drive.
