But what are your opinions on this product, i believe this is the best cpu coolers iv ever seen.
Im thinking of buying bulk lot for saveings, anyone else interested?
(sorry if this is the wrong section for this sorta thing, i didnt know where to put it)
Support the latest Intel Core i7 CPU
- Clip supports Intel scoket LGA1366 included
Stylish Appearance
- Classic Cylinder Heatsink and Spiral Aluminum Fins
Optimized Structure
- 6 Copper Heatpipes
- 80mm Blow Fan
- Low Noise Performance
- VR™ Fan Control
Smart Airflow Design
- Integrated with System Fan
- 360∘Heat dissipation
Note: Complimentary Intel Core i7TM socket 1366 CPU mounting mechanism will be
provided for any users who purchased SpinQ CPU cooler.
Stylish Appearance
- Cylinder Heatsink and Spiral Aluminum Fins are absolutely a presentation of aesthetics.
- Eye-catching Scurve™ Blade Fan plus blue LED makes it unforgettable
Optimized Structure
- 50 waved aluminum fins, 6 copper heatpipes and generates efficient cooling performance
- Mirror coating copper base conducts heat effectively from CPU and gets more surfaces to dissipate the heat
- Integrated with the System to maximize the cooling performance
- VR™ Fan allows the users to adjust the fan speed according to their needs. It makes good cooling effect at low speed
and generates minimum noise.
- Cylindrical Structure dissipates the hot air with 360∘
Model CL-P0466
Compatibility Intel Socket LGA 1366
Core i7
Intel Socket LGA 1156
Core i7
Core i5
Core i3
Intel Socket LGA 775
Core 2 Extreme
Core 2 Quad
Core 2 Duo
Pentium D
Pentium 4
Pentium
Celeron D
Celeron
AMD Socket AM2 / AM2+
Phenom II x4
Phenom II x3
Phenom
Athlon 64 FX
Athlon 64 X2
Athlon 64
Sempron
Heatsink Dimension 121.63mm x 90mm x 151.85mm
Heatsink Material 50 Aluminum Fins + Copper &
Aluminum Base
Heatpipe Ø 6mm x 6
Fan Dimension Ø 80mm x 85 mm
Rated Voltage 12 V
Started Voltage 7 V
Fan Speed 1000 ~ 1600 RPM
Power Input 5.4 W
Rated Current 0.45 A
Noise 19 ~ 28dBA
Life Expectation 50,000 Hours
Connector 3 Pin
Weight 667g
Stylish Appearance
Optimized Structure
- 80mm Blow Fan
- VR™ Fan Control
Stylish Appearance
Optimized Structure
Model CL-P0466
Core i7
Core i7
Core i5
Core i3
Core 2 Extreme
Core 2 Quad
Core 2 Duo
Pentium D
Pentium 4
Pentium
Celeron D
Celeron
Phenom II x4
Phenom II x3
Phenom
Athlon 64 FX
Athlon 64 X2
Athlon 64
Sempron
Aluminum Base
Heatpipe Ø 6mm x 6
Rated Voltage 12 V
Started Voltage 7 V
Power Input 5.4 W
Noise 19 ~ 28dBA
Connector 3 Pin
Weight 667g
