Full Version: Wtf?
74QEE
pulled into the servo last nite to buy smokes and i come out to my ute pissing out smoke and oil from the flywheel cover plate.i got under and had a look and its beyond me what is wrong with it.i filled it with trans fluid about a 3 hours b4 that and the trans fliud was already black.the car still drove fine and the auto shifted normally.could i have overfilled it or is it fucked..can some1 help me plzzzz!!! by the way its a trimatic with a stock 6 banger in front of it
Ratwagon
Normally it will piss out if its too full....coming from the area u described it could be a front pump seal too!!
Is it still hosing out now?
sussba
id say seeing u just filled it up it got over filled.. and the reson it went dark strait away is cos u need to flush it... u cant get all the fluid out by draining it cos the converter holds more than the pan itself..
74QEE
haha it hasnt done it again..wierd..maybe i just overfilled it..i think its time for a 4 speed
