saki636
Sep 11 2009, 05:23 PM
my zx6r turbo project
t2 garrett turbo, power commander, yoshi can, inprocess of making dump still gota make plenum and piping.
rhys420
Sep 11 2009, 05:32 PM
fuck thatd go hard
nice
BossTG
Sep 11 2009, 05:57 PM
Weapon.
boostnpulsar
Sep 11 2009, 06:12 PM
unreal mate...i know a fella with a 900 turbo...runs 9 flat(high 8's) at over 170....big balls and best of luck...have loved everyone of your posts mate.!!!
QIK TX5
Sep 11 2009, 06:55 PM
looking good , 600s are fast enough untouched.
shall be good
RAnee B
Sep 11 2009, 07:28 PM
should of gone bigger turbo if you goin threw that trouble.
still freakin sick mate
ashcroftracing
Sep 11 2009, 08:04 PM
nice mate, awesome work
matty_FMX
Sep 11 2009, 08:35 PM
wow, best of luck with that
saki636
Sep 12 2009, 09:30 AM
the way the radiator is curved it has been enough trouble to fit that size turbo, plus in not looking to make 200hp. I have mounted it as high as i could and still prob gona have to run a scavenge pump cos the oil level is pretty close to the centre of the turbo. the older bikes have a shorter radiator so easier to get the turbo up high. turbo should be fine others in the us have used same sorta size and starts to boost at about 7k which is good cos power band starts at about 9-10k revs out to 16.5k...even a 10 hp gain will be good enough, some people spend 2k on exhaust and 1k on cams and get same sorta gains. Im tryin to make it a total stealth install so no cutting of fairings. dump pipe is recycled xr6 turbo exhaust feeds back into the stock system, was thinkin of just having a short side exhaust but would be pretty loud and i have a underseat muffler so would look bit funny with big space there...also had a external wastegate but sorta no where to put it so gona try go with the stock one will prob port it out a bit and make a new flapper for it. just gona run 5-6psi for starters. stock 13.1 compression.
Oz_GixxA!
Sep 13 2009, 07:32 AM
good man... things gonna be sick as... you gonna extend the swingarm? ??? im looking at a turbo kit for my gixxer.. is it a custom or did you got somewhere ???
saki636
Sep 13 2009, 11:14 AM
QUOTE (Oz_GixxA! @ Sep 13 2009, 07:32 AM)
its all home made, i got some lowering links so the rear and was thinkin maybe gettin extended links for the rear want to try cut some low 10s maybe even a 9
best i could run stock was 11.2
theres a place in the us that sells kits for gsxr's pretty cheap about 3kish us tho
Oz_GixxA!
Sep 14 2009, 09:23 AM
Good plans mate. yea i duno if i really wanna turbo the beast lol. im looking at 1200 just for a nos sys.. and thats not even installed lol. but id have to say mate that thing will have so much lift by the time you get it all going and sweet..... i should hope to see you at willow sometime
saki636
Sep 14 2009, 06:06 PM
1200 for nos tell em there dreamings
bikes only need dry kits and you just add the extra fuel with the power commander theres even a plug in module that can run 2 maps hit the button for nos and it uses the map with the extra fueling should only cost few hundred all you need is a small bottle one solenoid and one sprayer and a full throttle button, full wet nos kits for cars with big bottle and twice the stuff you need for a bike is only $600-700. I seen a few bikes at the track with nos, I was thinkin of that route at one stage but just love da boost and something thats not so common
Oz_GixxA!
Sep 14 2009, 10:55 PM
yeah mate, i understand the boost thing lol. its more so the insurance thing that i am going for lol. nos i can unbolt lol... turbos i have to get off my arse lol
saki636
Sep 16 2009, 06:49 PM
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentnew pics got the oil feed and the water fittings, in the process of making the dump pipe tight squeeze
saki636
Oct 5 2009, 08:47 PM
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentwelded bracket to sump for wastegate, stock xr6 turbo actuator.
turbo fits nicely behind fairings hardly can even see it
Oz_GixxA!
Nov 16 2009, 08:27 PM
hey dude thats awesome.. if you dont mind me asking how much did that set up end up costing ya?
