Full Version: Do I Really Need A Trans Cooler
74QEE
i want to get rid of the trans cooler in my hz ute because it leaks like a bitch and i dont want to buy another 1.will the auto still run right without it? its only a six banger and gets driven about 10 ks everyday so it barely gets a chance to heat up and it doesnt get thrashed..can it be done????
Ratwagon
Can be done but Id advise against it...There should be a cooler inbuilt in the radiator unless your running a manual one....get auto radiator,refit steel factory lines,no leaks....WIN!!
74QEE
yeah im running a v8 manual radiator.i mite have to get a 6 banger1
Ratwagon
new oil cooler will be cheaper than a radiator man...check round a few swap meets or put in a wanted ad?? Egay? They are pretty cheap and will save yur tranny in the long run...the cooler the oil the better it performs....
Is it actually the cooler itself or a rubber line leaking around the clamp??
74QEE
its the rubber line.ive changed it like 3 times.the factory steel lines are still there but the wanker who i got the car off cut the fittings that screw into the radiator.and just attatched fuel line and clamps to the trans cooler.i had another look and its a v8 auto radiator.and the holes for the lines just have plugs in them.im gonna try and ring some wreckers today and get some new lines.ebay had nothing
