Hey guys
I am selling my T Trim setup on my car. It is a complete Bolt on setup for a Holden V8 EFI motor. Details as Below, what it comes with etc.
Posting it here coz i would like to keep it strictly to Victorians, i cannot be fucked with interstate selling, unless someone can chase up the courier fees themselves i am not going to unbolt this setup to get a estimated fee on shipping lol
  • V2 T-Trim unit Polished and Detailed with blower Air assist with 90 degree outlet
  • 50mm Gilmer tooth cut 14psi pulley kit with tensioner
  • Crank pulley with all bolts
  • Precision parts full steel harmonic balancer
  • Braided oil supply line and oil pump fittings
  • Braided air assist line
  • Return line to sump
  • Chromed bracket
  • All bolts included, those are polished too.
  • Alternator
  • Siemans Deka 65lb fuel injectors
  • 4 inch core 600x300 intercooler
  • 3" mandrel bent Custom fabricated intercooler setup no shortcuts taken, polished piping.
  • Turbosmart silicone joiners
  • Turbosmart Megasonic Type-III bov
  • All high pressure clamps
  • Oil sump included (if buyer can wait for me to remove motor)
  • Wet element big pod filter
Bought it last year August, Not to mention the epa's ive had with it so it was not used continously, also i only drive the car 3 times a month at the most.
Blower is capable of running 28-30psi
Intercooler setup is very convenient and efficient, all 3 pipes enter/exit through the 1 hole. Also running a massive pod behind the front bar..
Making 471rwkw on my 355 with tyre slip at only 15 degrees timing..
Reason for selling is the usual...same as every other year, again..going for another bigger engine combo and a bigger blower..
Will take offers between $8,000 - $10,000 ($8,000 and above)
email me or call
ssn8r@vnssclub.com or call 0435 249 005
