Unclegary
Aug 26 2009, 11:09 AM
hey guys
im having trouble winding my torsion bar down as i cannot crack the nut i have tryed using a breaker bar with a long pipe on the end for leverage, i tried to rattle gun it but the threaded peice is too long any tips for making it easier to undo???
Reverb_Lancer
Aug 26 2009, 12:24 PM
Give it a hit with a gimpie on a flat side to help loosen it up, spray some CRC on it too.
Otherwise there are freeze sprays that Loctite do to help free things up, or you can throw some heat into it.
Rookie ROX
Aug 26 2009, 12:58 PM
As with any torsion bar problems, there's a variety of methods.
You can spray it repeatedly with a lubricant like Inox/CRC/etc by spraying it in, leaving it for a few hours, spraying some more in and so forth over the course of a couple of days, and then try.
You can tap the side of the bar repeatedly like a tuning fork with the intention to loosen the splines. You can also slam the crap out of it with a large hammer hoping for the same effect (but risking damaging the bar).
You can heat up the splines as a method of expanding the metal allowing it to release properly.
You can combine all the methods together in a hope one will be the final key. Ultimately, it's about persistence. Every budge you get will help, so keep trying something until you get it loose. Then of course don't forget to note the original settings/position of the splines prior to any winding.
ROCK ON
R~R
TUF120
Aug 26 2009, 01:42 PM
right to tight, left to loose
Matto08
Aug 26 2009, 01:45 PM
Lift the front wheels off the ground takes pressure off the torsion bars
that_rodeo_guy
Aug 26 2009, 11:26 PM
QUOTE (Matto08 @ Aug 26 2009, 01:45 PM)
Should be doing that anyway. Pretty dangerous if you don't.
But yeah I had to use a breaker bar with a pipe on the end to get mine lol - and plenty of CRC. Like Rookie said... persistence
Matto08
Aug 27 2009, 08:36 PM
QUOTE (that_rodeo_guy @ Aug 27 2009, 12:26 AM)
He didnt state it, just putting it out there
that_rodeo_guy
Aug 27 2009, 10:27 PM
QUOTE (Matto08 @ Aug 27 2009, 08:36 PM)
Yeah true. All good
