QUOTE (ThunderBolt @ Aug 25 2009, 05:12 PM)
Only problem with the JustJap hubs (unless the hubs have now changed), is that they run screw-in wheel studs. Not so much a problem if you remember to loctite them, but if you snap one or more in the future, it isn't a simple process to get hold of replacements, as you will need to go through JustJap. No-one else supplies screw-in wheel studs.
Which is why I used WhiteR32's hubs, they are made of high grade materials and are very high quality. Standard press-in studs are used in them, hell if you are being cheap you can knock your old ones out and you only have to buy 2 wheel studs...
