k guys. my tacho stopped working thru a track day.
it will work when warming up but after a while it fails and drops down to 0.
if i hit a bump it will jump up...then back to zero. (i think this is more the fact that the needle jumps, not a loose connection)
My Power fc hand controller tacho works fine......it leads me to believe its a wiring issue behind the cluster.. However it is all fine!!??
i have also replaced the whole dash cluster and this EXACT problem still persists. i have also checked all my fuses.....and they are fine
ANY HELP OUT THERE GUYS.??
i have used contact cleaner to clean the ecu pins, and the ignition module in the engine bay, the connection pins for the tacho in the dash and still hasnt fixed the issue.
its getting VERY frustrating !!!
