QUOTE (JonJon @ Aug 16 2009, 07:43 PM)
At the moment i try and get 2 runs in per week. But would like to push myself to do more.
well if your already running, you can easily bump that up to three sessions a week. Have two of those sessions for interval training an the other at a constant pace.
Interval training, if you do it right, needs only last for half an hour per session. Use your other session to do a continuous 5k ( how far are you running now and at what time?) use it as a milestone, every week you should be bettering your time.
Also vary your routes to decrease boredom and keep your body guessing.
I like to use hill runs as my interval training. I bust to the top as quick as i can, then slowly jog down the other side to recover, then repeat on the next hill on my route, which is immediatly straight after
. Obviusly you don't have to do this, it's just an example, I do it because the hills are a good height and fit in with the 'work' time and it's not so boring.
you can use a treadmill or go outdoors with a stop watch, or take up kickboxing. Actually, kickboxing is the ultimate boredom buster for training.
Then throw in your strength training every other day. (3 days a week) Your body will get used to it, so don't let soreness in the first couple of weeks put you off. If you take it easy, you won't have any issues. Just stick to the core compound exercises (squats, deadlifts, bench e.t.c) start out with 2 sets each exercise, then bump it to 3 after a week or so. When you become more competent, start a 5x5 program and your strength should rocket.
Obviously start out light and slow, going full force straight away will just burn you out.
Cycle your routine and give yourself 1 or 2 dedicated rest days a week.
Actually what i've just planned out there might seem a bit hardcore, although I am doing something very similar to this and i'm not having any issues. But i've come from a very heavy sporting background.
