drfta_7
Jul 23 2009, 10:15 PM
check ebay really dont want to type out all the mods......
SALE OR SWAP!!!
http://shop.ebay.com.au/?_from=R40&_tr...-All-Categoriesoffer me cash or swap 0415499115
drfta_7
Jul 25 2009, 12:02 AM
Bottom end work:
-Forged internals.
-S15 linished crank.
-Honed block.
-ACL race series bearing & rings.
-ACL gudgeon pins and spiral locks.
-GReedy copy sump.
-Cometic 3 ply metal head gasket.
Head work:
-Ported & Polished.
-ARP head studs.
-Waggott Cams, inlet 276 exhaust 266.
-Crower heavy duty springs.
-Valve regrind.
-Valve stem seals.
-New rockers.
-Cam cap tunnel line bore & bearings.
-Tomei solid lifters & shim kit.
-HKS rocker stoppers.
Brake mods:
-Front 5stud conversion with s14 hubs.
-Front 4spot callipers & ventilated disks.
-Front endless brake pads.
-R32 GTR double diaphram brake booster.
-Rear R33 5studs conversion.
-Rear R32 GTR 2spot calliper conversion.
-DBA slotted disks.
-Grex rear brake pads.
-R32 GTST handbrake cable.
-Earls braided brake lines all round.
Wiring:
-Gold terminals & dry cell battery in box in boot.
-only nessasitiesleft in vehicle
-Apexi AVCR.
-Apexi Pen Turbo Timer.
-Apexi EL2 white face gauges, oil pree, oil temp, wat temp, boost.
-batery isolator switch (located at rear of vehicle)
-ignition missile switch
-fuel pump missile switch.
-toggle wippers, lights.
-push button start.
Suspension & Steering mods:
-cusco alloy castor rods.
-HSD HR coilvers all round.
-S14 steering rack (longer).
-Non hicas rear end cradle.
-Nismo lengthened wheel studs.
-Cusco strut braces all round.
-D-Project rear camber arms.
Enigine bay mods:
-Twin 12" thermo fans.
-koya aluminium radiator.
-N/A 60 mm throttle body.
-Pitwork belts.
-GReddy copy plennum.
-Billet fuel rail.
-680cc injectors.
-Custom intercooler pipes.
-HKS SSQ bov.
-Sard fuel pressure regulator.
-All speed flow fitting & braided lines.
-X-Force stainless steel low mount manifold (powder coated by competition coatings).
-HKS 2530 turbo.
-X-Force 3" dump pipe, staright through 3" exhaust, twin pipes at rear.
very loud!!! also got HKS split screamer just not fitted.
-Drift oil catch can.
-Custom power steering reseviour.
-Engine dampener.
-Drift 4" pod.
drfta_7
Oct 11 2009, 01:31 AM
not for sale anymore, finally finished it, check members rides for updated pics.
http://www.boostcruising.com/forums/index....howtopic=469299
