QUOTE (vh-holden @ Jul 13 2009, 09:53 PM)
My internet keeps dropping out. I'll be browsing the forums and external links will stop working. I can still browse the forum i'm in for a little bit, but eventually that drops out too.
Is anyone else having problems with dropouts? Particularly in the northern suburbs. Trying to work out if it is the modem or the provider.
If anyone wants to tell me that telstra is rubbish or anything like that, tell me in the random thread please.
So getting back to where this tread started...
Process of elimination.
Before you get started, log in to your modem and note down your current DSL status - 1. Connection speed 2. Line noise margin, up and down.(this should by somewhere between 6 & 12db)
Rather than mucking around changing filters, lines, modems, ect, unplug all additional equipment, just run a phone line to your modem (no filter, it's only for your phone) and LAN cable to your PC, so no routers or additional gear, make sure you unplug all phones, faxes ect, any other items that connect by wireless, mobiles, games consoles and so forth.
Resart your modem and recheck these figures, note any change.
Next, plug in 1 phone, call Bigpond tech support and ask then to do a line test, also tell them the numbers you jotted down earlier and ask if they are in an exceptable range. If all is good at Bigponds end and your line keeps dropping out, ask them to restet your account password.
Reset your modem back to factory default and re-enter you your details, if your modem is bigpond supplied, use your bigpond CD, it will ensure all setting are correct.
If you still have no luck, make sure windows is upto date, do a factory reset on Internet Explorer and a Windows disk clean up.
If still no luck, try to borrow a modem for testing or possibly consider buying a new one.
