Full Version: Front Brake Hub Set Up
offtaps13
i have an s13 with factory ca18 non turbo brakes. car now has sr20det with gt2871r turbo and other bits. i need some good stopping power as it is dangerously lacking in that department. i have a few thoughts not sure if they will work
1. continue using ca slotted front rotors and get some ebc greenstuff pads or something like that
2. get s15 or 300zx rotors etc and redrill to 4 stud will the calipers fit
3. get a full r32 front hub setup and convert to 5 stud
any help will be appreciated
offtaps13
dont worry i now have r33 gtst brakes redrilled to 4 stud. r33 lower control arms for camber and 20mm wheel spacers as my rims are wrong offset to begin with anyway
Seekers
it seems like your 5 stud conversion would be the best bet,all the other options may not be as good as the last option,with the 5 Stud S14 hub/caliper set up with better pads/disc would be much better..
