Full Version: Help, Anyone With A Exa Or Et
Boostcruising.com > Global Club Discussions > AU: Tasmania
[4CE-FED]
As it reads, need someone to come round so i can borrow an af meter and or cpu.
To sort out the issue with mine, wont drive on boost! will boost up but wont putt along.
In the lonnie area also
Adam
Baz
Bit more detail on what it's doing?..Does it jerk and splutter around 2,500 - 3,000 RPM and not hit boost at all?
[4CE-FED]
WELL, i pulled the motor out to rebuild it an it was boosting fine.
After it went back in it didn't want to see any boost at all, cleaned all the plugs for the computer an earth's for the lume.... that fixed the free rev issue an would boost up under full load fine..... as it is now u can floor it an it's tip top, but as u back off an the load comes off it's feels like the timing gets pulled right out an it loses power till the turbo stops spooling or u boot it again.
As the motor is all new it's not been past 4000 rpm. So the range it's playing up in is from 2500 to 3500.... changed coil, leads an plugs.
Adam
etking
air leak between turbo and inlet manifold? is the timing set to 15 degrees? check the plug into the AFM and the ECU
[4CE-FED]
Yeh timing is good, they are ment to have about 17 in them. it's on about 20 now to try an help the issue lol. keep the spark alive..... air leak in the cooler piping do it u think?
i have 2 spare ecu's if you want to test with .. you can come get them in blackmans bay
[4CE-FED]
well i might have to.... but wont drive the zuki down lol..
Baz
QUOTE ([4CE-FED] @ Jun 18 2009, 02:43 PM) *
Timing is advanced 15" ..Will have a sticker under your bonnet
PANDA
thsst right austen 15 is where its actually meant to be. If you grab an ecu and afm I can come round and help out if need be. there are about 15 different solutions for this issue lol
Oh yeh and did you check the diagnostics on the ecu yet? you get this problem with stuffed water temps sensors as well wink.gif
[4CE-FED]
i don't think the computer can tell me much due to the car it's sitting in. The book we was reading to sort out the lume said 12 to 17 is fine for timing lol... has a knock stopper anyway lol. I can't seam to find a Afm or ecu atm, but if your keen to come have a look that would be great. Its down dads workshop
Adam
etking
stop reading that book. set it at 15, not 14, not 16. the ECU is under the passenger seat and has a diagnosis on it using flashing LEDS, look underneath the ECU there is a sticker that tells you what to do and you will need the manual to tell you what the codes mean. knock sensor does virtually nothing. water temp sensor like matt has noted is a classic once the simple things have been checked.
[4CE-FED]
well the motor isn't in a Et or Exa, it's in a suzuki 4x4. so half the lune isn't being used... so the computer wont tell me much lol.... everyhting is wong for it....... but it was fine befor i pulled the motor out to rebuild it. An i moved the timing ford to see if that would stop it from being pulled back as much under boost an stop the braking down. With out sounding rude 1 or 2 deg in timing wont hurt anything mate lol. No huge boost in it
Baz
Of course the computer will tell you that the go is, Do a diagnostics test, If you don't know how to do it, go to www.n12turbo.com and download the E15ET manual
PANDA
might have to go have a looksies I think. I will bring the correct manual with me so we can check diags if need be. Il see what Im upto on the weekend or sometime thru the week
NickZ
I have both AFM and ECU for e15t. if matt wants to look at it ill be happy to lend them to him.
PANDA
its all cool now he found the leak. timing is kinda sorted by the sounds of it too smile.gif
Cheddle
i have two spare E15ET ecu's PM me if u want to borrow one
[4CE-FED]
yeh ended up being 2 small cracks in a pipe. was enough to make the lil thing play up....... but now the next issue is the turbo!!! anyone got a T25 layen about
Adam
[4CE-FED]
QUOTE (Baz @ Jun 19 2009, 04:40 PM) *
Needs to be dun while the car is driving!!! i have no speed sender, due to me having a 120y box behind it.(and it being and in a zuki 4x4). Not usen the Map ses either. So my friend i wouldn't of got much good info out of it. But thanks for the info. Timing issue was also down to the cam timing an the new head an block height.
Adam
