Features:
- A true show car look; light-up your engine bay!
- Internal volume is 20% larger than the standard manifold allowing for increased air flow to each cylinder bank
- Plenum is designed to allow for precise air separation and allocation to each of the six runners
- Shorter length runners with enlarged internal volume caters for rapid air flow
- Unrestricted air flow made possible through laser curved edges on both plenum and runners of manifold
- Complements performance cams, larger fuel injectors, fuel pumps and other such modifications very well.
- Increases performance at med-high RPM range
- Made of precision CNC machined cast aluminium
- Based on the GReddy R33 intake manifold design
- 9.5kg of solid cast aluminium - superior wall thickness!
- Throttle body is repositioned to the front of the plenum to maximize air flow efficiency
- Oversized 80mm intake port maximizes air intake capabilities and accepts most aftermarket throttle bodies including our 80mm TB
- Includes RB25DET adaptor which allows for the standard throttle body to be used with no extra fabrication (only one in Aus!)
- Comes with all the required nuts bolts & brackets, incl. silicone/rubber hoses to mount directly onto the R33's RB25DET engine
The only direct bolt-on RB25DET kit available online!
Finish: Electroplated Mirror Gloss
Condition: Brand New
Price: $535 including Delivery w/ Insurance
Contact: 0401599023 (anytime)
