Full Version: Need Help With Sub In Boot For Vs Statesman
shonkas88
Hey my Mum, yes my mum wants to put 2 subs in her vs statesman, the only problem is how do i hook it up and all and also she has got stock speakers and a stock cd player
so would i need to buy a new head unit and amp to power the sub ?
MY IS2
Well you definately gonna need a new amp and a bigone at that to power the two subs. Im sure you could hook it up to the factory cd player but i would get one with dual preouts it would give you amuch better sound.
Jusdrifn 86
Go to car stereo shops and look at head units that have dual or even triple pre-outs (make sure one pair is a designated sub output) then show the dude there the subs and buy an amp that will power them nicely, u could leave it at this but the big bass would drown the standard speakers out, get 2 pairs of 4inch splits to give some nice treble and mid range, should come out of the shop about $1200 poorer, about...
Mighty_Apollo
You would definately need an amp. you MIGHT need to get a head unit IF the current one doesn't have any rca outputs
once u get all the stuff then ask again how to do it and im sure u will get a response.
too slack to bother explaining it all right now. or someone will just show u
Spec83
U can get line level converters that convert the speaker wires from ya hu to RCA outs... but i would only use the alpine one which is ~$80-100...even then it is a little dodgya dn only really required if ya hu is integrated with ya air-con etc etc...
Go for a hu with atl east front and rear/sub switchable RCA outs.... then if ya get 2 x 4ohm 10 or 12's and a 4ch amp u can bridge the 4ch's to 2ch's... one for each sub! Then if u want to do it cheap get a prefab box and aim it through the skiport... job done!
prophecy
try not to spend anything under the 300-350 mark for a 2/4 channel amp
