Hi Joeblow19,
I have a gt4 engine but has a ct26 as well. I usume they are the same excect yours should be twin entry unlike the gt4's have single entry. I would suggest to turn the boost down asap! The stock turbo has crematic interals, which brand new is only good for 14psi-16psi. U maybe able to run 20psi on a standard turbo but u find it wont last very long. 1 Bar is = to 14.6 psi im sure, to be safe i would turn down to 10psi atleast until u get it comfirm that it is crematic interals.
If the turbo is going u can do quick check your self, if u pull off the intake side of the turbo and have a look and see if the compressor wheel is cutting into the houseing. Also check to see if there is any shaft play, hold the centre of the turbo and see if it moves up and down or side to side. It should only move slightly up and down, and while moveing it spin it slowly, listen for it touching the houseing. If u find there is exsesive movment or it is touching the house or maybe there are metal savings, dont drive it full stop! Arrange to get it fixed, driveing with a stuff turbo can lead to engine damage. Fixing a ct26 will mean highflowing = bigger, but can cost $2000.
As to your question about ct20b turbo i have no idea. Maybe check out www.mr2.com.au i think the web site is they have forums there that might help u out. Failing that there is www.toymods.com.au.
May guess is a ct20b turbo has a small exhuast houseing to the ct26. Keep in mind a ct26 is the same turbos that supras use. They just weigh alot more.
A high flow ct26 on a stock 3s running 14psi gives a punch i can vouche for that.
Hope that helps.
Nathan
