Full Version: Electronic Rustproofing
smart
Hi guys i dont want an argument on if you think it works or not.. im looking for a place to do it on the northside
i have a qoute for 410 from http://www.tintplus.com.au/ but thats over at mansfield. they qouted me 410.. which is a 6 pad system..
so yea any suggestions or experiences ? cheeeeeers
laynlow
look through the trading post for people that supply them then fit it yourself it will be cheaper and you'll know what to do if anything goes wrong. its not hard we did it on my mates lux
synergy
how big is your 4x4? arb do beach packs, which is 8 pads for 700ish... thats really the only thing ive ever gone to arb for. but yeah
plus u know its quality, and its not from a window tinting place
up 2 u.
I have fitted oodles of these kits and never use any less that 6 pads if your going on the beach!
smart
is it that hard to do? just mount the unit in the engine bay and then run the pads? i guess i could give it a go myself? twincam maybe u can gimme some tips ?
Its piss easy to do.
I always mounted the module on the firewall.
Pos straight to the battery make sure it has a good clean earth. take the paint off if you are bolting it to a panel.
Clean the spot the pad is going on with prepsol or wax and grease removed first, make sure there is NOTHING left behind.
Affix the pad.
Run a beed of silicone around the pad to seal it good, no need to go overboard, just enough so you can run your finger round it and make it smooth.
Repeat for all.
They work in series, so all the pads but one will have two wires on it, just daisy chain them, ie from the unit, into the first pad, then out of the first pad into the second etc etc, the las pad will have only one wire (duh)
Make sure ALL connections are done with solder and make sure you are good at it, get the solder into the wire, not just on the surface like i have seen alot of people do that claim they can use an iron.
DO NOT and i cant stress this enough, DO NOT use crimps at ALL. All the joins MUST have heat shrink over them.
Thats pretty much it.
Big_Red_
There's a place in Brendale. I think it's called Rust Free or something similar.
pta78
We used Electronic Rust Prevention Systems Ph: 1800 332 899.
A mobile qualified installer fitted it at work. Got six couplers on Dodge Ram, 2 engine bay, 2 rear cab and 2 chasis rail.
It is guaranteed for 5 years. You have to checkthe red light to make sure it is working. Haven't had any trouble as yet and no rust either.
