* The 6 slots brake disc is adopted as standard in the SD type by considering various factor, such as pad wear, squeal and the removal effect.
* The width, angle, and depth are decided carefully based on data of various races and tests.
* For 6 slots type, aggressive rotation (slots pointing forwards) is recommended for higher friction co-efficiency.
* Succeeded to limit judder by offsetting the place of slots at outer/inner.
A 20% higher friction co-efficiency for slotted rotor than without slotted was proven in the DYNO test. The maximum difference of friction co-efficiency at a particular braking point in our favour was 20%. Engine tuning or suspension tuning can not make any change in a vehicle safety directly, but a 20% higher μ generated by brake components tuning can improve a vehicle safety a lot more and give a sense of comfort to the driver. Slotted rotors are not only designed to shorten the lap-time in the race track, they are also designed to improve a vehicle safety. They are a highly safety-featured item with high performance. We hope that all drivers will experience the braking performance of our DIXCEL SD type (slotted rotors).
* An optimum anti-rust treatment is applied according to the vehicle model and its area of use.
Front Slotted Disk Set Subaru 4 Pot (Brembo) - $450.00
Front Slotted Disk Set Subaru 2 Pot - $450.00
Front Slotted Disk Set STi 5 x 114.3 PCD (Brembo) - $590.00
Front Slotted Disk Set STi 5 x 100 PCD (Brembo) - $590.00
Front Slotted Disk set Mitsubishi EVO 5-9 - $590.00
Front Slotted Disk Set GH8 MY08-09 WRX - $490.00
$20 Postage Australia-wide!
