QUOTE(Streeter @ Feb 15 2009, 10:35 AM) [snapback]1283580630[/snapback]
nissan made a pile of diffs around that time.
generally the NA cars got the r180 diff and the turbo cars go the r200 diff.
bonus is that the side flanges are the same width between the two so like turbomarch said you might be able to just swap the rear housing over.
differences that might cause problems are
ABS: the abs optioned cars have the abs sensor in the snout of the diff which makes it longer so you will have tail shaft hassles.
flanges: there are 5 and 6 bolt flanges so make sure that they also match. I think both the s14 and the r32 both got 6 bolt flanges so you should be good to go.
otherwise you have a good chance of just bolting it in.
^^^ as above
btw love your sig. Jesse,
I'm guessing you were getting a few PM's off here asking where your money/parts/car are?
