Full Version: 12a And 13b Rotary Gemini Conversions
SLIMER
Gemini conversion kits to suit 12A, 13B, Turbo and NON turbo rotary engines.
All complete ''BOLT IN'' conversions (no modifications needed).
These Kits will include:
Engine Mount (plate which bolts onto the front of the actual engine)
Crossmembers Left and Right which will bolt into original gemini mounting points (which will pass an inspection in every state in Australia). As they are bolted to the original mounting points of the gemini's.
Custom mad sump.
Gearbox mount to suit various gearboxes (just have to let me know which one you have)
Rubber mounts to suit (rubber or solid mounts).
High Tensile bolts to suit.
All kits are painted in 2pac High Gloss Black as standard (The kits can be painted in any colour of your choice at a small cost, only charged for the materials. There is no extra charge for having them painted).
These kits are $900 plus postage, can be posted anywhere in Australia.
Also available is a custom made clutch cable mechanism, (allows you to keep the original gemini clutch cable) which saves you alot of modifying and headaches trying to convert it over to hydrolic type. These mechanisms are $90 posted anywhere in Australia (or $70 if purcahsing a conversion kit). And are also a bolt in conversion. The first 10 kits sold will be given a FREE clutch cable mechanism as a promotional deal.
Optional Extras:
Custom High pressure/temp oil lines to fit front mount oil cooler.
Custom Radiator (alloy extra).
Wiring loom to suit all model geminis.
Extractors to suit.
Turbo manifold.
The kits are made so even people with little to no mechanical knowledge or skills can complete this conversion as it is ALL BOLT IN.
Fitting and drive in drive out packages available also.
Ask for a quote.
Contact Steve on
0421646875 or email slimers@optusnet.com.au or paintedbyslimer@hotmail.com
SLIMER
bump
