Task: Changing Avatar
Prerequisites: Nil
Outline: Forums -> Edit Profile -> Edit Avatar Settings (Located Under Personal Profile on the left)
Description: Avaters are located below your username on the left pane.
Note: Please remember that images can take up to 24 hours to update.
Steps:
  • Select Forums located in the Top Header
  • Scroll down and select Edit Profile <---- Shortcut
  • Select Edit Avatar Settings Located below Personal Profile on the left sidebar
  • Browse to the image that you are wanting to upload, or you can select one from our base gallery. Note: Images cannot be larger then 50KB and must be only .gif .jpeg .jpg .png
  • Select Update Avatar
::NOTE:: If the image does not update, please clear your IE cache - CRTL + F5
Update Complete
