Full Version: How to take off your turbo! - TurbostyleR
TurbostyleR
How to take off your turbo - this is useful for replacing turbo/exhaust gaskets.
Things of what to do, and what not to do!
First undo the two bolts connecting the front pipe to the catalytic converter... as you can see I have a special high flow
cat... Note: this is just a racing pipe used for on the drag strip, I have a fully functionaly
highflow cat that i bolt up every time i come home from the track.
Now undo the nuts that connect the dump pipe with the turbo. The yellow circles
indicate the appropriate nuts... Note: That red residue all over the gearbox
housing is due to my water line for the turbo springing a leak, i fixed this
This is a shot from underneath the car and the yellow circles indicate the
appropriate nuts to remove.
Finally gone the dump pipe wont bother us anymore! Just dont start the car like
this at 10pm like i did! hehehe... Note: I also attached the nuts back onto the
turbo studs so they dont get lost...thats just me though
Next step now is to drain the oil, alot of people suggested you didnt need to do
this as well as draining the water, and perhaps you dont. However I did it to
make the job less messy and i regret not draining the water lines as well!!!
Now I am removing the oil return line from turbo to sump. The clamp is circled
in yellow to make it easier to identify. This was easy to remove the clamp
however it was a bit tough to slide off the actual metal barb that comes off the
turbo...
Stupid me forgot to take more photos, but wat eventuated was, u put the new
thermostat into the engine. Attatch the self adhesive gasket to the thermostat
housing. Then you attach the housing so it looks like this.
Okay, this next picture looks a little weird, but this is the water drain line (i
think) in the middle of the turbo between the exhaust and compressor housing. I
have also started to remove some of the nuts that hold the turbo to the manifold
as well as taking out that ("banjo bolt" i think its called) draining the water from the turbo back to the motor...
Just disconnect any intercooler piping you have now as we are almost ready to
take out the turbo......
As you can tell by now i have fucked up! This is what NOT to forget....dont
forget to remove the bastard OIL FEED!!! its best to disconnect the oil feed at
the motor as its very easy to get to. And thats basically how to remove your
turbo and dump/front pipe...
Matt988
TurbostyleR
user posted image
user posted image
user posted image
user posted image
user posted image
my new turbo vs. my old turbo.....
d3ano304
TurbostyleR
To be honest I dont really want to say exactly what type of turbo it is...
all i'll let you guys know is that its slightly smaller than the Trust T78 and alot bigger than the Trust T67...
TurbostyleR
QUOTE (TurbostyleR @ Apr 3 2004, 01:30 AM)
forgot to mention that the "smaller" turbo is a T28 good for 210rwkw...
its in perfect condition also and for sale...
500 firm, located in brisbane
SOLD! 11.4.2004
Hyper Knight
haha ahmed nice tutorial, you need to write a "how to install huge fucker of a turbo onto an sr20det" tute.
nice work, eat17 shall be haulin ass once complete.
Nathan
nice article..
WRX-801
thats pretty risky tryin to take of ur own turbo huh.gif but if its good for u to do it its fine and keep it up
Paulie_Bro
hahahah... just noticed the golf balls... hahaha
great job
MR_JAZZ
how much for the t28?
d3ano304
he said $500 firm,wat rwhp u expecting to make with the new turbo?i wanna know if it's still safe for me to give u a run at willowbank?lol
TurbostyleR
QUOTE (d3ano304 @ Apr 3 2004, 12:45 PM)
Thanaks d3ano304, the turbo is $500 firm I already have one buyer but they are interstate and i preffer to sell in bribane than having to fuck around with shipping...
NOTE: The turbo was checked out this morning by a reputable and well known workshop thats doing my car and it is in perfect condition! (3.4.2004)
Im expecting anywhere from 270-300rwhp with this new turbo, but on stock injectors and computer...
The thing is i have an internal 500hp fuel pump and an external 600hp fuel pump with surge tank and a sard fuel pressure regulator so it will help the fueling with stock injectors....
however once I get my power fc and sard 850cc/min injectors im expecting 350rwhp+, that should be happening in about 3-4 weeks...
Then i might get solid lifters, and a new head for my car and put in some stage 3 cams and see if it wants to push 400hp at the rears...
with my old setup, single fuel pump, T28, fmic, exhaust, boost, etc etc, my car ran a pb of 13.00@109.2mph...that mph is good enough for easy mid to low 12's if the car could get traction!
SLO 33
Pennywise
are you going to use that turbo with your stock manifold? :/
CHARGER
QUOTE (Pennywise @ Apr 3 2004, 03:03 PM)
That turbo wouldnt fit next too the SR20 in a lo mount and is also a different stud pattern id assume its gunna be a custom highmount
TurbostyleR
QUOTE (CHARGER @ Apr 3 2004, 06:47 PM)
Exactly right charger...
17SLO
looks like a holset/schwitzer diesel turbo
"lack of wastegate - large exaust housing turbine - agressive compressor trim
*waives bye to any efficiency
.........just at a quick punt
HOLNESS
noice work mate cant wait to see what she runs at willow biggrin.gif thumbsup.gif
cheez
Spidey
I did a great job that night supervising the whole operation! lol
TurbostyleR
QUOTE (17SLO @ Apr 5 2004, 10:35 PM)
nope its not a holeset/schwitzer diesel turbo...
180degrees
roughly how long did this take you to do?
Barely Legal Customs
awesome article man...
sinnie
looks like one of the new apexi RX8 turbos?
anyway ahmed this looks sweet, and ur sil should be one of the quickest around. What sought of wategate are you going to run?
TurbostyleR
180degrees it took me about 4-5 horus to do and that includes jacking up the car draining the oil and taking the pictures etc etc...And mind you i didnt read up on this at all it was just a spur of the moment thing lol...
Pang: the external gate im running is a 45mm Turbonetics Deltagate and it should vent to atmosphere...and pang, your really really close on the type of turbo!!!
I should get my car back either tomorrow or next tuesday/wednesday sometime if im lucky! lol
Amokk
hmm is it an apexi ax series?
dreeft
PM Sent.
DICKIES
that turbooooo is big i like it going to fly once that baby is in thumbsup.gif
Paolo
Thankyou for that. I learnt something.
lil_jo
ORX400
weeeeeerd ahhhhmed
Silvia_Xtreme
lol.. just wait till you have to remove the exhaust manifold..
then try to remember how to put it all back together months after...
TurbostyleR
New turbo is in....
It makes similar horsepower as before however on much less boost i.e. its making aroudn 250hp at the wheels on 8psi of boost...
But it is a little laggy...full boost is at around 5500-6000rpm however this should drop about 300-500rpm once my computer arrives within the month...
One major side effect is the fact that the Airflow meter is causing me MASSIVE dramas, i.e It stalls alot and it sometimes cant even idle! This is due to the fact that the turbo is too big and the computer cant handle it, also because i put the airflow meter really close to the turbo is another factor of it mucking up...
So for the time being its just a lag monster, i'll take a few pictures and post them up soon...
51AMU
That's quite a large turbo you have there!!!! Car should see some good number's once it's on!!!!
Chucky
Dammm. Now i know where i placed that turbo of me 16V92.
16V92 is a turbo diesel. V-16. 92cu per cylinder . . .
ahpeeyem
QUOTE (Chucky @ May 4 2004, 10:38 PM)
Hrmmm...
GT4
that should chop. i wish i had cash for a bigger turbo
Rob
whats happening with the car, is it soughted and do you have timeslips....
Silly Silvia
i thought i would update now lol...
The car has run a best of 12.9@124mph on 18psi of boost with a dead stock motor - power levels where at 300rwhp on PITS dyno.
I have made more power due to a set of cams (power went up to 330rwhp on 17psi) on PITS dyno so trap speeds should be good for 127-128mph...
Currently re-building the motor and hoping for 135mph+ trap speeds and later on perhaps getting a 10 on street tyres..
Talin A.k.A TAZMC
fark cant wait to see pictures..
caseyjohnphotography
Good article
StageD
Different dump i see
Heated Up
Man when was the last time u used warerproofer under the hood??? RUST!!!!!
yea good work mate
